在powerpcb5.0里面,怎样检查pcb的nets和原理图的nets相同与否?
这个应该是可以检查的啊,难道没人会吗?
tools/compare netlis(原理图asc,选original design)和(Use Current PCB Design)new designoutput 选options/generate differences report.比较.
我是主持人,煸情功夫一流。我是工程师,刻苦学习一生。我是海王星,透明蓝色一体。因为有了你,我就一通百通。
谢谢斑竹
我按照你说的方法,点击RUN后,就会显示ECOGEN failed,
PowerPCB ECO Generator (Version 6.0g) 2006-3-16 10:19:48
Copyright (c) 1995-2001 Innoveda, Inc. - All rights reserved
ASCII reading (part types and decals) - 32 msec
ASCII reading (part types and decals) - 8 msec
Reading the OLD DESIGN
There are 0 parts in the design
There are 0 signals in the design
There are 0 pins in the design
ASCII reading (parts, nets, attributes) - 1 msec
为什么会这样啊?
有可是你的ASC格式不正确,你可以把刚从原理图导好的的PCB再导成ASC文件作为原始档保存,以后完成Layout时再compare,若没有问题会出现如下的Layout.log:
PADS Layout ECO Generator (Version 6.1b) 2006-03-16 12:38:42
Copyright (c) 2003 Mentor Graphics Corp. - All rights reserved
ASCII reading (part types and decals) - 15 msec
ASCII reading (part types and decals) - 0 msec
There are 81 parts in the design
There are 91 signals in the design
There are 330 pins in the design
ASCII reading (parts, nets, attributes) - 282 msec
Reading the NEW DESIGN
ASCII reading (parts, nets, attributes) - 453 msec
Final cost=8
Partitioning - 0 msec
Final Matching - 0 msec
Deleted pins: 0, Added pins: 0
哦,的确如此,谢谢谢谢!
