为什么DCM出不来倍频,各位帮看看!
为什么DCM出不来倍频,各位帮看看!
我调用了一个DCM,输入输出直接MAP出来。为什么仿真结果倍频出不来,请高手帮帮忙!!!!
难道DCM不能这么用?
输入24MHZ,想出来48MHZ。而且下图是CLKIN_IN在下降沿时才出来的,上升沿只有LOCK有输出。
上升沿
entity yl is
PORT(
  CLKIN_IN : IN std_logic;
  CLKIN_IBUFG_OUT : OUT std_logic;
  CLK0_OUT : OUT std_logic;
  CLK2X_OUT : OUT std_logic;
  LOCKED_OUT : OUT std_logic
end yl;
architecture Behavioral of yl is
signal a: std_logic;
COMPONENT dcm1
 ORT(
 END COMPONENT;
begin
Inst_dcm1: dcm1 PORT MAP(
  CLKIN_IN =>CLKIN_IN ,
  CLKIN_IBUFG_OUT => CLKIN_IBUFG_OUT ,
  CLK0_OUT => CLK0_OUT,
  CLK2X_OUT =>a ,
  LOCKED_OUT => LOCKED_OUT
CLK2X_OUT<=a;
end Behavioral;
撒幅度
我觉得楼上说的对,你看看换个名字试试
