飞思卡尔MC9S12NE64串口收发问题求助
小弟开始用MC9S12NE64做串口转以太网的工程,可是程序使用PE BDM MULTILINK写到单片机里面,全速运行时出错,请高手指点下可能是什么问题,在板子上烧流水灯的程序可以正常运行下面是我的代码:
#include <hidef.h>
#include <mc9s12ne64.h>
uchar data;
//----------PLL初始化----------//
void clockinit(void)
    CLKSEL_PLLSEL=0;
    PLLCTL_PLLON=0;      //turn off PLL
    SYNR =0x01;
    REFDV=0x01;          //pllclock=2*osc*(1+SYNR)/(1+REFDV)=50MHz,busclk=pllclk/2=25M;
    PLLCTL_PLLON=1;      //turn on PLL
    _asm(nop);
    _asm(nop);
    _asm(nop);
    _asm(nop);
    while(!(CRGFLG_LOCK==1));   //the pll is stable
    CLKSEL_PLLSEL =1;           //engage PLL to system;
    COPCTL = 0x00;              //disable watchdog
//----------串口SCI1初始化----------//
void sciinit(void)
   SCI1BDL=0xA3; //bus clock is 25Mbaud rate is 9600
   SCI1BDH=0x00;
   SCI1CR1=0x00; //8 bits of data,1 bit of stop
   SCI1CR2=0XAC; //admit receive and transmit interrupt,admit receive and transmit
//----------IO初始化----------//
void IOinit(void)
  DDRG=0XFF;
  PTG=0X00;
//----------主函数----------//
void main(void)
   DisableInterrupts;
   clockinit();
   sciinit();
   IOinit();
   PEAR_NECLK=0;
   EnableInterrupts;
   while(!SCI1SR1_RDRF);
//----------SCI1中断响应函数----------//
#pragma CODE_SEG NON_BANKED
interrupt 21 void SCI1_Isr(void)
  data=SCI1SR1;
  data=SCI1DRL;               //read received character + clear interrupt flag
  PTG=0X40;                     //set transceiver chip for transmit
  while(!SCI1SR1_TDRE);    //SC1DR is busy,wait
  SCI1DRL=data;              //set transceiver chip for receive
  data=SCI1SR1;
  PTG=0X00;
#pragma CODE_SEG DEFAULT
望高手指点啊,不胜柑橘
