大家看看我用VHDL编的FIFO程序,那错了
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
--  Uncomment the following lines to use the declarations that are
--  provided for instantiating Xilinx primitive components.
--library UNISIM;
--use UNISIM.VComponents.all;
entity SYFIFO is
 generic(FIFO_Depth : integer :=10; FIFO_Width : integer :=10);
 port(
   read_clock_in : in std_logic;
   write_clock_in : in std_logic;
   read_enable_in : in std_logic;
   write_enable_in : in std_logic;
   full_out : out std_logic;
   empty_out: out std_logic;
   reset_in : in std_logic;
   write_data_in : in std_logic_vector(FIFO_Width-1 downto 0);
   read_data_out : out std_logic_vector(FIFO_Width-1 downto 0));
end SYFIFO;
architecture FIFOArc of SYFIFO is
 type BlockRam is array (0 to FIFO_Depth-1) of std_logic_vector(FIFO_Width-1 downto 0);
 signal RAM : BlockRam;
 signal read_clk : std_logic;
 signal write_clk : std_logic;
 signal read_enable : std_logic;
 signal write_enable : std_logic;
 signal full : std_logic;
 signal empty : std_logic;
 signal reset : std_logic;
 signal read_addr : integer range 0 to FIFO_Depth-1;--std_logic_vector(9 downto 0);
 signal write_addr : integer range 0 to FIFO_Depth-1;--std_logic_vector(9 downto 0);
begin
 read_enable <= read_enable_in;
 write_enable <= write_enable_in;
 read_clk <= read_clock_in;
 write_clk <= write_clock_in;
 full_out <= full;
 empty_out <= empty;
 reset <= reset_in;
 --读地址指针信号的产生
 proc1:process(read_clk,reset)
 begin
 if (reset='1') then
  read_addr <= FIFO_Depth-1;
 elsif (read_clk'event and read_clk='1') then
  if (read_enable='1' and empty='0') then
   if (read_addr=FIFO_Depth-1) then
    read_addr<=0;
   else
    read_addr <= read_addr+1;
   end if;
  end if;
 end if;
 end process proc1;
 --写地址指针信号的产生
 proc2:process(write_clk,reset)
 begin
 if (reset='1') then
  write_addr <= 0;
 elsif (write_clk'event and write_clk='1') then
  if (write_enable='1' and full='0') then
   if(write_addr=FIFO_Depth-1) then
    write_addr <=0;
   else
    write_addr <= write_addr+1;
   end if;
  end if;
 end if;
 end process proc2;
 ---读操作
 proc3:process(read_clk)
 begin
   read_data_out <= RAM(read_addr);
  end if;
 end if;
 end process proc3;
 ----写操作
 proc4:process(write_clk)
 begin
   RAM(write_addr) <= write_data_in;
  end if;
 end if;
 end process proc4;
 --空标志和读使能信号的产生
 proc5:process(read_clk,reset)
 begin
 if (reset='1') then
  empty <= '1';
  read_enable <= '0';
  if ((read_addr=write_addr-2 or (read_addr=FIFO_Depth-1 and write_addr=1) or (read_addr=FIFO_Depth-2 and write_addr=0)) and (read_enable='0' and write_enable='1')) then
   empty <='1';
   read_enable <= '0';
  elsif (empty='1' and  write_enable='0') then
   empty <='0';
   read_enable <= '1';
  end if;
 end if;
 end process proc5;
 --满标志和写使能信号的产生
 proc6:process(write_clk,reset)
 begin
 if (reset='1') then
  full <= '0';
  write_enable <= '0';
  if (read_addr=write_addr and read_enable='1' and write_enable='0') then
   full <='1';
  elsif (full='1' and read_enable='0') then
   full <='0';
   write_enable <= '1';
  end if;
 end if;
 end process proc6;
 ---输出空满标志信号
 proc7:process(write_clk)
 begin
  full_out <= full;
  empty_out <= empty;
   end if;
 end process proc7;
end FIFOArc;
,这个程序不能综合,急急急!!!!
把报错信息发上来,这样更好分析些
看人家的程序是种痛苦!~ 无比痛苦!~!
给个参考给你,好像比你编的要好点
library IEEE;
use IEEE.Std_logic_1164.all;
entity FIFOMXN is
generic(m, n : Positive := 8); --m is fifo depth, n is fifo width
port(RESET, WRREQ, RDREQ, CLOCK : in Std_logic;
DATAIN : in Std_logic_vector((n-1) downto 0);
DATAOUT : out Std_logic_vector((n-1) downto 0);
FULL, EMPTY : inout Std_logic);
end FIFOMXN;
architecture V2 of FIFOMXN is
type Fifo_array is array(0 to (m-1)) of Bit_vector((n-1) downto 0);
signal Fifo_memory : Fifo_array;
signal Wraddr, Rdaddr, Offset : Natural range 0 to (m-1);
signal Rdpulse, Wrpulse, Q1, Q2, Q3, Q4 : Std_logic;
signal Databuffer : Bit_vector((n-1) downto 0);
begin
--pulse synchronisers for WRREQ and RDREQ
--modified for Synplify to a process
sync_ffs : process
begin
wait until rising_edge(CLOCK);
Q1 <= WRREQ;
Q2 <= Q1;
Q3 <= RDREQ;
Q4 <= Q3;
end process;
--concurrent logic to generate pulses
Wrpulse <= Q2 and not(Q1);
Rdpulse <= Q4 and not(Q3);
Fifo_read : process
begin
if RESET = '1' then
Rdaddr <= 0;
Databuffer <= (others => '0');
elsif (Rdpulse = '1' and EMPTY = '0') then
Databuffer <= Fifo_memory(Rdaddr);
Rdaddr <= (Rdaddr + 1) mod m;
end if;
end process;
Fifo_write : process
begin
if RESET = '1' then
Wraddr <= 0;
elsif (Wrpulse = '1' and FULL = '0') then
Fifo_memory(Wraddr) <= To_Bitvector(DATAIN);
Wraddr <= (Wraddr + 1) mod m;
end if;
end process;
Offset <= (Wraddr - Rdaddr) when (Wraddr > Rdaddr)
else (m - (Rdaddr - Wraddr)) when (Rdaddr > Wraddr)
else 0;
EMPTY <= '1' when (Offset = 0) else '0';
FULL <= '1' when (Offset = (m-1)) else '0';
DATAOUT <= To_Stdlogicvector(Databuffer) when RDREQ = '0'
else (others => 'Z');
end V2;
