触控设备手势唤醒的设计思路及其实现
触控设备手势唤醒的设计思路及其实现
示例代码2
  // example interrupt function where this might be implemented
  __interrupt void TimedInterrupt( void )
  uint8 proximity_counts;
  uint8 filtered_counts;
  if ( device_status == SLEEP_MODE )
  // read one byte from register 0x16
  proximity_counts = read_i2c_register(MAX44000_ADDR,0x16,1);
  // weights[QUEUE_SIZE] contains the filter weights for the FIR filter
  // data_queue[QUEUE_SIZE] is a FIFO queue meant to be the input to the filter
  filtered_counts = fir_filter(proximity_counts,weights,data_queue);
  if (filtered_counts 》 WAKEUP_THRESHOLD)
  device_status = WAKE_MODE;
  else
  // do whatever it is you need to in sleep mode
  * fir_filter()
  * Implements an FIR filter in the form
  * y = w[0]*x[0] + w[1]*x[1] + 。。.+ w[QUEUE_SIZE]*x[QUEUE_SIZE]
  * Arguments:
  * uint8 input - newest datapoint taken (that is, x[0])
  * uint8 *weights - w[0]。。.w[QUEUE_SIZE]
  * uint8 *queue - the discrete sequence x[0]。。.x[QUEUE_SIZE]
  * Returns:
  * The FIR-filtered output, y
  uint8 fir_filter(uint8 input, uint8 *weights, uint8 *queue)
  uint8 i;
  int sum = 0;
  // pop first entry in the queue, then
  // push new data into the last position
  push_into_queue(queue,input);
  // input is now x[0]
  for (i=0; i {
  sum += weights[i]*queue[i];
  return (sum/QUEUE_SIZE);
  }示例代码3
  // this handles hardware-level interrupts on the micro
  __interrupt void irq_handler( void )
  // if the hardware interrupt came from the MAX44000 sensor
  // pulling its INT pin low
  if ( irq_source == MAX44000 )
  // if the device is in sleep mode
  if (device_status == SLEEP_MODE)
  device_status = WAKE_MODE; // wake up the device
  // reconfigure whatever else you need here as the system wakes up
  // otherwise, handle it however it is you wish
  else
  * configure_max44000_for_sleep_mode()
  * Sets up the MAX44000 to trigger a hardware interrupt when the proximity
  * counts go above some set threshold.
  * Arguments:
  * uint8 upper_threshold - the set threshold (8-bit mode)
  * Returns:
  * n/a
  void configure_max44000_for_sleep_mode(uint8 upper_threshold)
  uint8 max44000_thresh_registers[] = {0x0B,0x0C};
  uint8 max44000_upper_thresh[] = {0x40,0};
  max44000_upper_thresh[1] = upper_threshold;
  // do a consecutive write of 0 followed by upper_threshold to
  // registers 0xB and 0xC, respectively
  // MAX44000_ADDR is usually 0x94
  // interrupt will trigger only if proximity value is above the threshold
  write_i2c_register(MAX44000_ADDR,max44000_thresh_registers,
  max44000_upper_thresh,2);
  // write to bits 2 and 3 of register 0x0A here if you wish to set the
  // persist time to anything other than one sample
  // writes to register 0x01 to enable interrupts on the MAX44000
  max44000_enable_interrupt();
  return;
