ENTITY fsm IS PORT(x,y,clk:IN BIT;z:OUT BIT); END fsm; ARCHITECTURE su OF fsm IS COMPONENT logical_part PORT(in0,in1,q0,q1:IN BIT;d0,d1:OUT BIT); END COMPONENT; COMPONENT memory_part PORT(d_in0,d_in1,clk:IN BIT;d_out0,d_out1:OUT BIT); END COMPONENT; SIGNAL IS1,IS2,IS3,IS4:BIT; BEGIN c1:logical_part PORT MAP(x,y,IS2,IS3,IS4,z); c2:memory_part PORT MAP(IS3,IS4,clk,IS1,IS2); END su; ENTITY logical_part IS PORT(in0,in1,q0,q1:IN BIT;d0,d1:OUT BIT); END logical_part; ARCHITECTURE dataflow OF logical_part IS BEGIN d0<=(in0 AND q0)OR(x AND q1); d1<=(NOT q0)AND(NOT q1)AND in_0; out1<=(NOT in_0)AND(NOT in_1)AND q0; END dataflow; ENTITY memory_part IS PORT(d_in0,d_in1,clk:IN BIT;d_out0,d_out1:OUT BIT); END memory_part; ARCHITECTURE dataflow OF memory_part IS BEGIN BLOCK(clk='1' AND clk'event) BEGIN d_out0<=GUARDED d_in0; d_out1<=GUARDED d_in1; END BLOCK END dataflow;
请问这个程序应该写在一个文件还是3个文件,无论我写在一个文件还是3个文件都有很多错误请各位指点 |
