我用的ALTERA公司的nios2 软核,在系统生成的时候还是正常的。
但是到编译的时候就会出现下面的问题:
Error: Selected device has 20 RAM location(s) of type M4K RAM. However, the current design needs more than 20 to successfully fit.
Error: Can't fit design in device
Error: Quartus II Fitter was unsuccessful. 2 errors, 16 warnings
Error: Quartus II Full Compilation was unsuccessful. 2 errors, 202 warnings
当我将JTAG模块去掉时,编译不会出现上面问题,但是有很多的警告:
请大哥帮忙解决一下
