求:适于LIN应用的12V到5V的电源转换芯片,最好是freescale的![求助]
怎么没有人发应啊?freescale电源转换的芯片是什么型号? 指点一下啊!
5V的稳压芯片太多了,没有功耗要求的可以使用7805,有功耗要求的可以使用一些开关电源芯片
使用国半的LM5007吧
LM5007,效率比较高可达90%左右,外围电路比较简单,一个电感几个电阻.成本也比较低.
不过LM5007的输出电流<=500mA,如果功率要求比较大的话,可以选用其他型号的芯片.[em24]
for slave node, try MC33689
http://www.freescale.com.cn/products/analog/Chinese_Information.asp
Freescale ic 全线代理(原摩托罗拉) 弘忆国际 Product Marketing:Sifachen(陈兴华) http://www.freescale.com.cn (飞思卡尔) Tel:0755-33388219 FAX:755-33388206、33388207 Mobile:13723451581 MSN:haihuaxing@hotmail.com ADD:深圳市罗湖
如果从节点就选用集成了LIN2.0收发功能的SBC芯片MC33689;如果是主节点,一般这个主节点是CAN-LIN网关,所以可以选用集成了CAN收发器的SBC芯片,低速的有:MC33889,MC33389,高速的MC33989
以下是Freescale Support提供的参考:
As a physical interface you can use one of the following
For CAN:
MC33742, High Speed, Dual 5.0V regulator
http://www.freescale.com/files/analog/doc/data_sheet/MC33742.pdf
MC33389, Low Speed, Dual 5.0V LDO regulator
http://www.freescale.com/files/analog/doc/data_sheet/MC33389.pdf
MC33889, Low Speed, 5.0V LDO regulator
http://www.freescale.com/files/analog/doc/data_sheet/MC33889.pdf
For LIN:
MC33689, 5.0V
http://www.freescale.com/files/analog/doc/data_sheet/MC33689.pdf
MC33399, just physical layer
http://www.freescale.com/files/analog/doc/data_sheet/MC33399.pdf
Currently there is not part that has both LIN and CAN so you will have to use two of the options of above.
