[求助]求DSP5402和DSP2407芯片的英文介绍、
这些东西你到TI的网站上很容易找到: www.ti.com
****DSP5402:****
Description:
The TMS320VC5402 fixed-point, digital signal processor (DSP) (hereafter referred to as the '5402 unless otherwise specified) is based on an advanced modified Harvard architecture that has one program memory bus and three data memory buses. This processor provides an arithmetic logic unit (ALU) with a high degree of parallelism, application-specific hardware logic, on-chip memory, and additional on-chip peripherals. The basis of the operational flexibility and speed of this DSP is a highly specialized instruction set.
Separate program and data spaces allow simultaneous access to program instructions and data, providing the high degree of parallelism. Two read operations and one write operation can be performed in a single cycle. Instructions with parallel store and application-specific instructions can fully utilize this architecture. In addition, data can be transferred between data and program spaces. Such parallelism supports a powerful set of arithmetic, logic, and bit-manipulation operations that can be performed in a single machine cycle. In addition, the '5402 includes the control mechanisms to manage interrupts, repeated operations, and function calls.
Fertures:
Advanced Multibus Architecture With Three Separate 16-Bit Data Memory Buses and One Program Memory Bus
40-Bit Arithmetic Logic Unit (ALU), Including a 40-Bit Barrel Shifter and Two Independent 40-Bit Accumulators
17-× 17-Bit Parallel Multiplier Coupled to a 40-Bit Dedicated Adder for Non-Pipelined Single-Cycle Multiply/Accumulate (MAC) Operation
Compare, Select, and Store Unit (CSSU) for the Add/Compare Selection of the Viterbi Operator
Exponent Encoder to Compute an Exponent Value of a 40-Bit Accumulator Value in a Single Cycle
Two Address Generators With Eight Auxiliary Registers and Two Auxiliary Register Arithmetic Units (ARAUs)
Data Bus With a Bus-Holder Feature
Extended Addressing Mode for 1M × 16-Bit Maximum Addressable External Program Space
4K x 16-Bit On-Chip ROM
16K x 16-Bit Dual-Access On-Chip RAM
Single-Instruction-Repeat and Block-Repeat Operations for Program Code
Block-Memory-Move Instructions for Efficient Program and Data Management
Instructions With a 32-Bit Long Word Operand
Instructions With Two- or Three-Operand Reads
Arithmetic Instructions With Parallel Store and Parallel Load
Conditional Store Instructions
Fast Return From Interrupt
On-Chip Peripherals
Software-Programmable Wait-State Generator and Programmable Bank Switching
On-Chip Phase-Locked Loop (PLL) Clock Generator With Internal Oscillator or External Clock Source
Two Multichannel Buffered Serial Ports (McBSPs)
Enhanced 8-Bit Parallel Host-Port Interface (HPI8)
Two 16-Bit Timers
Six-Channel Direct Memory Access (DMA) Controller
Power Consumption Control With IDLE1, IDLE2, and IDLE3 Instructions With Power-Down Modes
CLKOUT Off Control to Disable CLKOUT
On-Chip Scan-Based Emulation Logic, IEEE Std 1149.1 (JTAG) Boundary Scan Logic
10-ns Single-Cycle Fixed-Point Instruction Execution Time (100 MIPS) for 3.3-V Power Supply (1.8-V Core)
Available in a 144-Pin Plastic Low-Profile Quad Flatpack (LQFP) (PGE Suffix) and a 144-Pin Ball Grid Array (BGA) (GGU Suffix)
51 c8051f(f020,f040) msp430 arm(2410,2510) fpga(xc3s4000) dsp(5116 dm642) keilc vc++ matlab linux protel Ten_layerPCB mpegx h.26x Rscode Turbocode ofdm VideoBroadcasting ldpc_code(now!) |
****dsp2407****
The TMS320LF240xA and TMS320LC240xA devices, new members of the TMS320C24x™ generation of digital signal processor (DSP) controllers, are part of the TMS320C2000™ platform of fixed-point DSPs. The 240xA devices offer the enhanced TMS320™ DSP architectural design of the C2xx core CPU for low-cost, low-power, and high-performance processing capabilities. Several advanced peripherals, optimized for digital motor and motion control applications, have been integrated to provide a true single-chip DSP controller. While code-compatible with the existing C24x™ DSP controller devices, the 240xA offers increased processing performance (40 MIPS) and a higher level of peripheral integration. See the TMS320x240xA Device Summary section for device-specific features.
The 240xA generation offers an array of memory sizes and different peripherals tailored to meet the specific price/performance points required by various applications. Flash devices of up to 32K words offer a cost-effective reprogrammable solution for volume production. The 240xA devices offer a password-based "code security" feature which is useful in preventing unauthorized duplication of proprietary code stored in on-chip Flash/ROM. Note that Flash-based devices contain a 256-word boot ROM to facilitate in-circuit programming. The 240xA family also includes ROM devices that are fully pin-to-pin compatible with their Flash counterparts.
All 240xA devices offer at least one event manager module which has been optimized for digital motor control and power conversion applications. Capabilities of this module include center- and/or edge-aligned PWM generation, programmable deadband to prevent shoot-through faults, and synchronized analog-to-digital conversion. Devices with dual event managers enable multiple motor and/or converter control with a single 240xA DSP controller. Select EV pins have been provided with an "input-qualifier" circuitry, which minimizes inadvertent pin-triggering by glitches.
The high-performance, 10-bit analog-to-digital converter (ADC) has a minimum conversion time of 375 ns and offers up to 16 channels of analog input. The autosequencing capability of the ADC allows a maximum of 16 conversions to take place in a single conversion session without any CPU overhead.
A serial communications interface (SCI) is integrated on all devices to provide asynchronous communication to other devices in the system. For systems requiring additional communication interfaces, the 2407A, 2406A, 2404A, and 2403A offer a 16-bit synchronous serial peripheral interface (SPI). The 2407A, 2406A, and 2403A offer a controller area network (CAN) communications module that meets 2.0B specifications. To maximize device flexibility, functional pins are also configurable as general-purpose inputs/outputs (GPIOs).
To streamline development time, JTAG-compliant scan-based emulation has been integrated into all devices. This provides non-intrusive real-time capabilities required to debug digital control systems. A complete suite of code-generation tools from C compilers to the industry-standard Code Composer Studio™ debugger supports this family. Numerous third-party developers not only offer device-level development tools, but also system-level design and development support.
Features:
High-Performance Static CMOS Technology
25-ns Instruction Cycle Time (40 MHz)
40-MIPS Performance
Low-Power 3.3-V Design
Based on TMS320C2xx DSP CPU Core
Code-Compatible With F243/F241/C242
Instruction Set and Module Compatible With F240
Flash (LF) and ROM (LC) Device Options
LF240xA: LF2407A, LF2406A, LF2403A, LF2402A
LC240xA: LC2406A, LC2404A, LC2403Z, LC2402A
On-Chip Memory
Up to 32K Words x 16 Bits of Flash EEPROM (4 Sectors) or ROM
Programmable "Code-Security" Feature for the On-Chip Flash/ROM
Up to 2.5K Words x 16 Bits of Data/Program RAM
544 Words of Dual-Access RAM
Up to 2K Words of Single-Access RAM
Boot ROM (LF240xA Devices)
SCI/SPI Bootloader
Up to Two Event-Manager (EV) Modules (EVA and EVB), Each Includes:
Two 16-Bit General-Purpose Timers
Eight 16-Bit Pulse-Width Modulation (PWM) Channels Which Enable:
Three-Phase Inverter Control
Center- or Edge-Alignment of PWM Channels
Emergency PWM Channel Shutdown With External PDPINTx\ Pin
Programmable Deadband (Deadtime) Prevents Shoot-Through Faults
Three Capture Units for Time-Stamping of External Events
Input Qualifier for Select Pins
On-Chip Position Encoder Interface Circuitry
Synchronized A-to-D Conversion
Designed for AC Induction, BLDC, Switched Reluctance, and Stepper Motor Control
Applicable for Multiple Motor and/or Converter Control
External Memory Interface (LF2407A)
192K Words x 16 Bits of Total Memory:
64K Program, 64K Data, 64K I/O
Watchdog (WD) Timer Module
10-Bit Analog-to-Digital Converter (ADC)
8 or 16 Multiplexed Input Channels
500 ns MIN Conversion Time
Selectable Twin 8-State Sequencers Triggered by Two Event Managers
Controller Area Network (CAN) 2.0B Module (LF2407A, 2406A, 2403A)
Serial Communications Interface (SCI)
16-Bit Serial Peripheral Interface (SPI) (LF2407A, 2406A, LC2404A, 2403A)
Phase-Locked-Loop (PLL)-Based Clock Generation
Up to 40 Individually Programmable, Multiplexed General-Purpose Input/Output (GPIO) Pins
Up to Five External Interrupts (Power Drive Protection, Reset, Two Maskable Interrupts)
Power Management:
Three Power-Down Modes
Ability to Power Down Each Peripheral Independently
Real-Time JTAG-Compliant Scan-Based Emulation, IEEE Standard 1149.1 (JTAG)
Development Tools Include:
Texas Instruments (TI) ANSI C Compiler, Assembler/Linker, and Code Composer Studio™ Debugger
Evaluation Modules
Scan-Based Self-Emulation (XDS510™)
Broad Third-Party Digital Motor Control Support
Package Options
144-Pin LQFP PGE (LF2407A)
100-Pin LQFP PZ (2406A, LC2404A)
64-Pin TQFP PAG (LF2403A, LC2403A, LC2402A)
64-Pin QFP PG (2402A)
Extended Temperature Options (A and S)
A: –40°C to 85°C
S: –40°C to 125°C
