合资电子制造公司中国研发中心高薪诚聘
Senior PCB Layout Design Engineer
Duty and Responsibilities  erform schematics capture Generate and update bill of material Layout floor planning, physical layout, routing, and verification including DRC, LVS, and LPE Layout techniques to improve circuit performance. Work with hardware designer to define optimal layout solutions, based on design objectives Component symbol and footprint library creation Qualifications/Capabilities: Bachelor degree or above in electronics is preferred 3 years experience in high speed PCB design with more than 8 layers. Schematics capture using Cadence Concept HDL Create and maintain symbol & footprints library  lacement and routing using Cadence Allegro or Mentor Graphics tools In-depth knowledge in EMC, Signal integrity simulation Gerber out and DFM check using valor 5000 Well spoken and written English is a requirement for the positions
[此贴子已经被一通百通于2006-3-28 8:55:05编辑过] |
