【Urgent Question】 Codewarrior Bug or Code error ? ---About The FFT function dfr16RFFT
When i use the function-dfr16RFFT in   E to execute a FFT. It doesn't work well,Although i strictly follow the instructions of   E's manual ,It does not work well . My code goes following . i'm wondering what's wrong with it ? does Anyone can give me an example of the function dfr16RFFT which give the same result of the answer from Matlab "fft([0.1 0.2 0.3 0.4],8)"
ans =
1.0000 -0.0414 + 0.7243i -0.2000 - 0.2000i 0.2414 + 0.1243i -0.2000 0.2414 - 0.1243i -0.2000 + 0.2000i -0.0414 - 0.7243i
Thanks A lot!!!!!!!
void main(void) { /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/ /*** End of Processor Expert internal initialization. ***/
/* Write your code here */ dfr16_tRFFTStruct *pRFFT; Result res; Frac16 pX[]={FRAC16(0.1),FRAC16(0.2),FRAC16(0.3),FRAC16(0.4)}; UInt16 options = FFT_SCALE_RESULTS_BY_N;
dfr16_sInplaceCRFFT *pZ=malloc(sizeof(dfr16_sInplaceCRFFT));
   E_low_level_init(); pRFFT = dfr16RFFTCreate (8, options); /* N = 8 point RFFT */ res = dfr16RFFT (pRFFT, pX, pZ); dfr16RFFTDestroy (pRFFT); for(;  {} } ===================== |
