MODELSIM的问题
MODELSIM的问题
仿真时老出现这样的语句不能仿真,大侠们侃侃有可能是什么问题呢
Launching Application for process "Generate Expected Simulation Results".
Reading C:/Modeltech_xe/tcl/vsim/pref.tcl
# 5.6e
# do aa.ado
listening on address 127.0.0.1 port 1200
# ** Warning: (vlib-34) Library already exists at "work".
# resume
# Model Technology ModelSim XE II vcom 5.6e Compiler 2002.10 Oct 22 2002
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Loading package std_logic_arith
# -- Loading package std_logic_unsigned
# -- Compiling entity count
# -- Compiling architecture behavioral of count
# Model Technology ModelSim XE II vlog 5.6e Compiler 2002.10 Oct 22 2002
# -- Compiling module aa
# Top level modules:
#  aa
# vsim -lib work -t 1ps aa
# Loading work.aa
# XE version supports only a single HDL
# ** Error: (vsim-3039) aa.ant(23): Instantiation of 'count' failed.
#         Region: /aa
# Error loading design
ERROR: VSim failed to simulate annotated testbench
多谢版主!
不过现在 还是 没有解决
没有找到问题的关键!
# The checkout offeature xe-vhdl has been disallowed .Failure 83.
# ** Error:Failure to obtain a vhdl simulation license.
#Error loading design
ERROR:VSim failed to simulate annotated testbench
我们老师现在要我做一个关于8051IP核的东西,
所以在网上搜索了一个8051IP核
只有时钟同步异步的时候 可以仿真,
我直接把它的全部源代码放进去综合的
不知道这种IP核这样子对不对,
请斑竹指点,我把代码给你帮我看看,谢谢http://bbs.chinaecnet.com/uploadImages/8051IP.rar
