一段小程序,老是仿真出现问题如下:
Launching Application for process "Generate Expected Simulation Results".
Reading C:/Modeltech_5.7/tcl/vsim/pref.tcl
# 5.7
# do bb.ado listening on address 127.0.0.1 port 1200 # ** Warning: (vlib-34) Library already exists at "work". # resume # Model Technology ModelSim SE vcom 5.7 Compiler 2002.12 Dec 18 2002 # -- Loading package standard # -- Loading package std_logic_1164 # -- Loading package std_logic_arith # -- Compiling entity i8051_dec # -- Compiling architecture dfl of i8051_dec # Model Technology ModelSim SE vlog 5.7 Compiler 2002.12 Dec 18 2002 # -- Compiling module bb # # Top level modules: # bb # vsim -lib work -t 1ps bb # Attempting stack trace sig 11 # Signal caught: signo [11] # vsim_stacktrace.vstf written # Current time Thu Apr 13 14:53:23 2006 # ModelSim Stack Trace # Program = vsim # Id = "5.7" # Version = "2002.12" # Date = "Dec 19 2002" # Platform = win32 # 0 0x004c6023: '<unknown (@0x4c6023)> + 0x20ff3' # 1 0x004c5f4e: '<unknown (@0x4c5f4e)> + 0x20f1e'
# Corrupt Call Stack
# Loading work.bb # Loading C:/Modeltech_5.7/win32/../std.standard # Loading C:/Modeltech_5.7/win32/../ieee.std_logic_1164(body) # Loading C:/Modeltech_5.7/win32/../ieee.std_logic_arith(body) # Loading work.i8051_dec(dfl) # ** Fatal: (SIGSEGV) Bad pointer access. # Time: 0 ps Iteration: 0 Process: /bb/UUT/line__38 File: ../8051/8051/i8051_dec.vhd # FATAL ERROR while loading design # Error loading design Error loading design ERROR: VSim failed to simulate annotated testbench
源代码如下:
library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.STD_LOGIC_ARITH.all;
entity i8051_dec is port( rst : in STD_LOGIC; op_in : in UNSIGNED (7 downto 0); op_out : out UNSIGNED (8 downto 0)); end i8051_dec;
architecture DFL of i8051_dec is
begin process(rst,op_in) begin if(rst='1') then op_out<=("000000000" ); else case op_in is when "00010001"=>op_out <=("010000000" ) ; when others=>op_out<="111111111" ; -- ("00" & OPC_ERROR ); end case; end if; end process; end DFL; |
