1.锁相环PLL:phase locking loop 2.MPLL:main PLL 3.MPLLCON寄存器:main PLL control register 4.AHP总线:Advanced High performance Bus 5.APB总线:Advanced Peripheral Bus 6.LOCKTIME寄存器:LOCK TIME COUNT register 7.CLKDIVN寄存器:CLOCK DIVIDER CONTROL register 8.CAMDIVN寄存器:CAMERA CLOCK DIVIDER REGISTER 10.12.起步石:stepping stone SDRAM高速缓冲器
一、内存管理单元MMU
1.内存管理单元MMU:Memory Management Unit
2.高速缓冲存储器:Cache
3.虚拟地址VA:virtual address
4.变换后的虚拟地址MVA:modified vitual address
5.物理地址PA:physical address
6.页表:page table
7.条目:entry 或 deor
8.段:section
9.页表基址TTB:translation table base
10.粗页表基址:coarse page table base address
11.细页表基址:fine page table base address
12.大页表基址:large page base address
13.小页基址:small page base address
14.极小页基址:tiny page base address
15.描述符的域:domain
16.不对齐产生的异常:alignment fault
17.无权访问产生的异常:domain fault
18.转译查找缓存TLB:Translation Lookaside Buffers |
