# Loading work.compare_test_v_tf # ** Error: (vsim-19) Failed to access library 'cpld_ver' at "cpld_ver". # No such file or directory. (errno = ENOENT) # ** Error: (vsim-19) Failed to access library 'uni9000_ver' at "uni9000_ver". # No such file or directory. (errno = ENOENT) # Loading work.compare # ** Warning: (vsim-3009) [TSCALE] - Module 'compare' does not have a `timescale directive in effect, but previous modules do. # Region: /compare_test_v_tf/uut # Loading work.glbl
用ISE编辑好文件后,用Modelsim仿真出现以上信息?是modelsim 的设置问题吗?
