Discuz! info: Can not connect to MySQL server
Time: 2024-6-7 11:51pm
Script: /viewthread.php
Error: Out of memory; check if mysqld or some other process uses all available memory; if not, you may have to use 'ulimit' to allow mysqld to use more memory or you can add more swap space
Errno.: 1041
Similar error report has been dispatched to administrator before.
到 http://faq.comsenz.com 搜索此错误的解决方案
