一次性将FPGA配置文件和软件代码写到EPCS flash中的路径和EPCS基地址就可以。
根据工程设置SOF,ELF,CDF文件路径
@ @ rem Altera EPCS program bat tool @ rem Written by Tiny Fu(Fu Hanjie), 2006-04-14 @ @ @ rem Project variables @ rem You must change these four variables according your project. @ rem @ rem ***** You must change SOF_FILE_NAME, ELF_FILE_NAME, EPCS_BASE. ***** @ rem @ rem example: SOF_FILE_NAME=C:\altera\test\standard\standard.sof @ rem example: CDF_FILE_NAME=C:\altera\test\standard\standard.cdf @ rem example: ELF_FILE_NAME=C:\altera\test\standard\software\hello_world\Debug\hello_world.elf @ rem example: EPCS_BASE=0x02200000 @ rem @ rem @ rem There should be no space between '=' and the value' @ rem It result in problems with this kind of sentence: EPCS_BASE= 0x02200000 @ set SOF_FILE_NAME=C:\altera\yout_quartus_project_dir\your_file.sof @ set CDF_FILE_NAME=C:\altera\yout_quartus_project_dir\your_file.cdf @ set ELF_FILE_NAME=C:\altera\yout_nios_ide_project_dir\your_file.elf @ set EPCS_BASE=your_epcs_base_address
@ if not exist %QUARTUS_ROOTDIR%\bin\cygwin\bin\bash.exe goto errorQ @ if not exist %SOPC_KIT_NIOS2%ios2_sdk_shell_bashrc goto errorN
@ rem Erase flash program @ rem nios2-flash-programmer.exe --epcs --base=%EPCS_BASE% --erase-all
@ rem Download FPGA first quartus_pgm --lower_priority %CDF_FILE_NAME%
@ rem Program SOF file and ELF to EPCS flash bash %SOPC_KIT_NIOS2%/bin/sof2flash --epcs --input=%SOF_FILE_NAME% --output=%SOF_FILE_NAME%.flash %SOPC_KIT_NIOS2%/bin/nios2-flash-programmer.exe --epcs --base=%EPCS_BASE% %SOF_FILE_NAME%.flash bash %SOPC_KIT_NIOS2%/bin/elf2flash --epcs --after=%SOF_FILE_NAME%.flash --input=%ELF_FILE_NAME% --output=%ELF_FILE_NAME%.flash --boot=%SOPC_KIT_NIOS2%/components /altera_nios2/boot_loader_epcs.srec %SOPC_KIT_NIOS2%/bin/nios2-flash-programmer.exe --epcs --base=%EPCS_BASE% %ELF_FILE_NAME%.flash
@ rem You can delete 'rem' in the No.45 line to read the contents in the EPCS flash. @ rem You can add 'rem' in the No.45 line to read the contents in the EPCS flash. @ rem The file name is SOF_FILE_NAME_readback.flash @ rem example, do not read back: @ rem %SOPC_KIT_NIOS2%/bin/nios2-flash-programmer.exe --epcs --base=%EPCS_BASE% --read %SOF_FILE_NAME%_readback.flash @ rem example, read back: @ %SOPC_KIT_NIOS2%/bin/nios2-flash-programmer.exe --epcs --base=%EPCS_BASE% --read %SOF_FILE_NAME%_readback.flash @ rem ------------------------------------------------- @ rem %SOPC_KIT_NIOS2%/bin/nios2-flash-programmer.exe --epcs --base=%EPCS_BASE% --read %SOF_FILE_NAME%_readback.flash
@ @ exit :errorQ @ echo . @ echo . Cannot locate Quartus installation (QUARTUS_ROOTDIR) at: @ echo . @ echo . %QUARTUS_ROOTDIR% @ echo . (specifically, the bin\cygwin\bash.exe program within) @ echo . @ echo . Please check your paths and try again (running Quartus from @ echo . the Start Menu may update the paths and fix this problem). @ echo . @ pause @ exit
:errorN @ echo . @ echo . Cannot locate Nios II Development Kit (SOPC_KIT_NIOS2) at: @ echo . @ echo . %SOPC_KIT_NIOS2% @ echo . (specifically, the nios2_sdk_shell_bashrc file within) @ echo . @ echo . Your Nios II installation may need to be repaired. @ echo . @ pause @ exit
@ REM : end of file
