我用ISE8.1 软件进行到要生成FPGA配置文件,就是双击Processes For Current Source 窗口中的Generate Programmming File 图标时出现以下错误,请各位大侠帮帮忙!
ERRORortability:3 - This Xilinx application has run out of memory or has
encountered a memory conflict. Current memory usage is 84848 kb. Memory
problems may require a simple increase in available system memory, or
possibly a fix to the software or a special workaround. To troubleshoot or
remedy the problem, first: Try increasing your system's RAM. Alternatively,
you may try increasing your system's virtual memory or swap space. If this
does not fix the problem, please try the following: Search the Answers
Database at support.xilinx.com to locate information on this error message.
If neither of the above resources produces an available solution, please use
Web Support to open a case with Xilinx Technical Support off of
support.xilinx.com. As it is likely that this may be an unforeseen problem,
please be prepared to submit relevant design files if necessary.
