一个让ISE8.1虾米的模块,不信你试试?
说来也奇怪
简简单单的一个序列监测器,功能就是监测电路连续的三个高电平。
在Mentor Precision、Synplicify Pro、QuartusII5.1里顺利综合通过,网表正确显示;
唯独ISE编译综合得驴唇不对马嘴,结果的RTL图和元件图看了令人崩溃。
你们试试,看看是怎么回事?最后生成的的电路图明显错误。
module Seq_Rec_3_1s_Moore (D_out, D_in, En, clk, reset);
  output   D_out;
  input   D_in, En;
  input   clk, reset;
  parameter  S_idle = 0;  // One-Hot
  parameter  S_0 =  1;
  parameter  S_1 =  2;
  parameter  S_2 =  3;
  parameter S_3 =  4;
  reg  [2:0]  state, next_state;
  always @ (negedge clk)
    if (reset == 1) state <= S_idle; else state <= next_state;
   always @ (state or D_in) begin
    case (state)
      S_idle: if ((En == 1) && (D_in == 1)) next_state = S_1; else
                     if ((En  == 1) && (D_in == 0))  next_state = S_0;
  else     next_state = S_idle;
      S_0:  if (D_in == 0)    next_state = S_0; else
  if (D_in == 1)    next_state = S_1;
      S_1:  if (D_in == 0)    next_state = S_0; else
  if (D_in == 1)    next_state = S_2;
      S_2, S_3: if (D_in == 0)    next_state = S_0; else
  if (D_in == 1)    next_state = S_3;
      default:        next_state = S_idle;
    endcase
  end
  assign D_out = (state == S_3);   // Moore output
endmodule
