可不可以将两个XDCP并连或串连来提高电阻值精度或分辨率?
Sure you can as find in p. 29 of my presentation.
You can control one XDCP at a time by switching the CS pin of our XDCP. In such configure, you can use one MCU and the same bus |
可不可以将两个XDCP并连或串连来提高电阻值精度或分辨率?如果这样的话,怎样安排这两个XDCP所具有的两个控制器?是以一个控制器为主进行编程控制,还是两个控制器同时编程控制,还是有其它方法? |
