请问哪位用过edk
请问哪位用过edk
edk中有一个xmd还有software debgger点击这两项中的一项都会出现
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
 Driver windrvr6.sys version = 6.2.2.2. LPT base address = 0378h.
 ECP base address = 0778h.
Cable connection failed.
Cannot Open Cable.
Unable to connect to PowerPC target.
        Make sure the PPC405 JTAG signals are Connected to JTAGPPC primitive and
 Cable Connections are Correct
这样的提示
我的问题是 这个lpt1应该接到什么地方?
高手指点
还有一个问题是我下载到板子上之后怎么察看结果
是不是就是用上面的
xmd?
请问这个软件还需要其他的连接吗
这问题就要沉底了
在使用edk时遇到下了问题,请高手指点
ERROR:MDT - Unable to locate the precompiled library lib_common_v1_00_a. The
file
d:\EDK\hw\XilinxProcessorIPLib\pcores\lib_common_v1_00_a\hdl\vhdl\addr_iet_in
c_ip_bus.vhd is distributed by Xilinx encrypted and will not be read by any
simulator. Please use compedklib to setup the EDK precompiled libraries and
provide the path to them using the -E switch.
Generating simulator helper scripts ...
make: *** [simulation/behavioral/ml310_base_system.do] Error 1
