向edk高人请教
向edk高人请教
在用edk时遇到下列问题,请高手指教
XMD%
Loading XMP File..
WARNINGortability:111 - Message file "EDK.msg" wasn't found.
Processor(s) in System ::
PowerPC405(1) : ppc405_0
Address Map for Processor ppc405_0
  (0x00000000-0x0fffffff) DDR_SDRAM_32Mx64      plb
  (0xfc000000-0xfc001fff) docm_cntlr    docm
  (0xfe000000-0xfe001fff) iocm_cntlr    iocm
  (0xfffe0000-0xfffe1fff) RS232_Uart    plb->plb2opb->opb
  (0xfffe2000-0xfffe207f) SPI_EEPROM    plb->plb2opb->opb
  (0xfffe2080-0xfffe20ff) SysACE_CompactFlash   plb->plb2opb->opb
  (0xfffe2100-0xfffe211f) opb_intc_0    plb->plb2opb->opb
  (0xfffe2200-0xfffe23ff) LEDs_8Bit     plb->plb2opb->opb
  (0xfffe2400-0xfffe25ff) LCD_OPTIONAL  plb->plb2opb->opb
  (0xfffe2600-0xfffe27ff) IIC_Bus       plb->plb2opb->opb
  (0xffff8000-0xffffffff) plb_bram_if_cntlr_1   plb
PowerPC405(2) : ppc405_1
Address Map for Processor ppc405_1
Executing Connect Cmd: connect ppc hw -cable type xilinx_platformusb port USB2 frequency 6000000 -debugdevice cpunr 2
icacheStartAdr 0x10000000 itagStartAdr 0x10010000 dcacheStartAdr 0x10020000 dtagStartAdr 0x10030000 tlbStartAdr 0x10050000
dcrStartAdr 0x10040000 Connecting to cable (Usb Port - USB22).
Checking cable driver.
 File C:\WINDOWS\system32\drivers\xusbdfwu.sys not found.
Inf File = C:\WINDOWS\inf\oem11.inf.
 Found version. DriverVer=12/29/2004, 1.0.1.7.
version =  1.0.1.7.
inf version = 1017(decimal).
Driver file not found. Inf file version = 0.
 Driver xusbdfwu.sys version: 1017 (1017).
 Driver windrvr6.sys version = 6.2.2.2.Cable connection failed.
write cmdbuffer failed 2000000F.
Cannot Open Cable.
Unable to connect to PowerPC target.
        Make sure the PPC405 JTAG signals are Connected to JTAGPPC primitive and Cable Connections are Correct
Connecting to cable (Parallel Port - LPT1).
 Driver windrvr6.sys version = 6.2.2.2. LPT base address = 0378h.
 ECP base address = 0778h.
Cannot Open Cable.
还有就是这里的xmd是说明书里带的,请问这个xmd是干什么用的
谢谢
谢谢
不过好像没有回答我的问题
什么时候才会有人来回复阿
等的好痛苦
在xilinx网站上找到了,可惜他说需要pack1,但是在xilinx网站上只能找到pack2
郁闷
Problem Description:
Keywords: EDK, XPS, XMD, PPC, FX40, FX60
Urgency: Hot
General Description:
After downloading a bitstream to the device using iMPACT H.38 and PAR IV cable and disconnecting the cable, I start XMD by opening a EDK Cygwin Shell and running "xmd".
When connecting to the cable using "connect ppc hw", I receive the following output:
XMD% connect ppc hw
ECP hardware is detected.
Cable connection established.
Connecting to cable (Parallel Port - LPT1) in ECP mode.
Driver xpc4drvr.sys version = 1.0.4.0. LPT base address = 0378h.
ECP base address = 0378h.
ECP port test failed. Using download cable in compatibility mode.
INFO:EDK - Assumption: Selected Device 2 for debugging.
JTAG chain configuration
Device ID Code IR Length Part Name
1 0a001093 8 System_ACE
2 01eb4093 10 XC4VFX60
Unable to connect to PowerPC target. Invalid Processor Version No 0x00000000
XMD%
Solution 1:
This problem has been fixed in the latest EDK 7.1i Service Pack available at:
http://support.xilinx.com/xlnx/xil_sw_updates_home.jsp
The first service pack containing the fix is EDK 7.1i Service Pack 1.
If the service pack does not resolve your problem please refer to (Xilinx 18265).
这是在执行什么的时候出现的?
让楼主等了一年,真是汗
哪位高人回答一下!
就是download bitstream的时候出现这个问题.
