用DS1302做的可调时钟
用DS1302做的可调时钟
/*名称:单片机读取DS1302时钟芯片,带调整功能                      /
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
#define xiemiao 0x80
#define xiefen  0x82
#define xieshi  0x84
#define xieri   0x86
#define xieyue  0x88
#define xiezhou 0x8a
#define xienian 0x8c
#define dumiao  0x81
#define dufen   0x83
#define dushi   0x85
#define duri    0x87
#define duyue   0x89
#define duzhou  0x8b
#define dunian  0x8d
#define kongzhi 0x8e
uchar rem[8]={0,3,10,5,1,10,5,1};
uchar bcd[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
uchar HSHI,LSHI,moshi,shanjishu;
uint  j;
bit SR_1,S_1,aj_1,shan_1;
sbit CS1=P1^0;       ////显示器选择线
sbit CS2=P1^1;
sbit E=P1^2;
sbit SCLK=P2^0;      ////DS1302管脚定义
sbit DIO=P2^1;
sbit DCE=P2^2;
sbit SB1=P2^7;       ////按键定义:时日选择键
sbit SB2=P2^6;       ////调整模式键
sbit SB3=P2^5;       ////加加键
sbit SB4=P2^4;       ////减减键
sbit ACC_7=ACC^7;
yanshi(uint kk)
while(kk--);
///////////////////////显示
xianshi()
uchar i;
for(i=0;i<8;i++)
  if(shan_1)if(i==moshi)i=i+2;
  P0=~(0x01<<i);
  E=0;
  CS2=0;
  E=1;
  CS2=1;
  P0=bcd[rem];
  E=0;
  CS1=0;
  E=1;
  CS1=1;
  yanshi(10);
  P0=0xff;
  E=0;
  CS1=0;
  E=1;
  CS1=1;
     shanjishu++;
  if(shanjishu==200)
    shanjishu=0;
    shan_1=~shan_1;
////////////////////////////向DS1302写数据
xieds1302(uchar dizhi,shuju)
{uchar i,tem;
DCE=0;
SCLK=0;
DCE=1;
for(i=0;i<8;i++)            //地址传输
   SCLK=0;
   tem=dizhi;
   DIO=(bit)(tem&0x01);
   dizhi>>=1;
      SCLK=1;
for(i=0;i<8;i++)          ///数据传送
   SCLK=0;
   tem=shuju;
   shuju>>=1;
   SCLK=1;
DCE=0;
/////////////////////////////////////读取DS1302的数据
duds1302(uchar dizhi)
uchar i,tem,temp;
temp=0;
DCE=0;
SCLK=0;
DCE=1;
for(i=0;i<8;i++)                ////传送地址
   SCLK=0;
   tem=dizhi;
   dizhi>>=1;
   SCLK=1;
for(i=0;i<8;i++)             ////读取数据
    ACC_7=DIO;
    SCLK=0;
       ACC>>=1;
    SCLK=1;
DCE=0;
temp=ACC;
LSHI=temp&0x0f;
HSHI=(temp&0xf0)>>4;
/////////////////////////////////读取时间
dushijian()
    duds1302(dumiao);        ///读秒
    rem[0]=LSHI;
rem[1]=HSHI;
duds1302(dufen);          ///读分
rem[3]=LSHI;
rem[4]=HSHI;
    duds1302(dushi);          ///读时
rem[6]=LSHI;
rem[7]=HSHI;
//////////////////////////////读取日期
duriqi()
    duds1302(duri);         /////  读日
    rem[0]=LSHI;
rem[1]=HSHI;
duds1302(duyue);        //////////读月
rem[3]=LSHI;
rem[4]=HSHI;
    duds1302(dunian);       /////////读年
rem[6]=LSHI;
rem[7]=HSHI;
xieshijian(uchar wei,hwei)
uchar he;
                   xieds1302(kongzhi,0x00);
                  he=rem[wei]+rem[hwei]*16;
      if(wei==0)xieds1302(xiemiao,he);
      if(wei==3)xieds1302(xiefen,he);
      if(wei==6)xieds1302(xieshi,he);
       xieds1302(kongzhi,0x80);
xieriqi(uchar wei,hwei)
{uchar he;
      if(wei==0)xieds1302(xieri,he);
      if(wei==3)xieds1302(xieyue,he);
      if(wei==6)xieds1302(xienian,he);
tiaozheng(uchar wei)
uchar hwei;
hwei=wei+1;                                                   //每数两位,低位是wei高位是hwei
if(aj_1)
     if(SB3==0)                                            ////是否SB3按下,加加键
    xianshi();
    if(SB3==0)
    aj_1=0;                                         ////
    while(SB3==0)xianshi();
          if(SR_1)                                           ////是不是日期
      rem[wei]++;                                     ////低位加加
         if(rem[wei]>9)
       rem[hwei]++;                                    //高位加加
       rem[wei]=0;
       if(rem[hwei]>9)rem[hwei]=0;
      if(wei==0)if(rem[1]==3)if(rem[0]==2)rem[0]=rem[1]=0;//日够31归零调整
      if(wei==3)if(rem[4]==1)if(rem[3]>2)rem[3]=rem[4]=0;//月到12归零调整
      xieriqi(wei,hwei);
       else
     rem[wei]++;
     if(rem[wei]>9)
       rem[wei]=0;
       rem[hwei]++;
       if(rem[hwei]==6)rem[hwei]=0;                  ///是分秒时够60归零
     if(wei==6)if(rem[7]==2)if(rem[6]>4)rem[7]=rem[6]=0;//是时时够24小时归零
     xieshijian(wei,hwei);                                 //时间写入DS1302
    if(SB4==0)
    xianshi();
       if(SB4==0)                                                    ///减法键
    aj_1=0;
    while(SB4==0)xianshi();
    if(SR_1)                                               /////是否显示日期
     if(rem[wei]==0)                                  ///低位是否为零
        if(rem[hwei]==0)                        /////高位是否为零
         if(wei==0){rem[1]=3;rem[0]=1;}          ///是日归31
         if(wei==3){rem[3]=2;rem[4]=1;}         ///是月归12
         if(wei==6){rem[6]=rem[7]=9;}          /////是年归99
      else {rem[hwei]--;rem[wei]=9;}                  ///高位减减低位变9
     else rem[wei]--;
     xieriqi(wei,hwei);                              //日期写入DS1302
           else
       if(rem[wei]==0)
        if(rem[hwei]==0)
          if(wei==6){rem[6]=4;rem[7]=2;}
       else {rem[wei]=9;rem[hwei]=5;}
     else rem[wei]--;
///////////////////////////////////////////按键
anjian1()                          ///按键1
if(SB1)if(SB2)if(SB3)if(SB4)aj_1=1;
if(aj_1)if(SB1==0)
      aj_1=0;
      xianshi();
   if(SB1==0)
      while(SB1==0)xianshi();
      SR_1=~SR_1;
anjian2()
if(aj_1)if(SB2==0)
      aj_1=0;
      xianshi();
   if(SB2==0)
       while(SB2==0)xianshi();
       moshi=moshi-3;      //模式减三,正好是时,分,秒,日,月,年的低位
       if(moshi>6)moshi=9;
void main (void)
SB1=SB2=SB3=SB4=1;
moshi=9;
DCE=0;
  while(1)
    if(moshi==9)
    if(SR_1)duriqi();
    else dushijian();
xianshi();
anjian1();//模式时日选择
anjian2();//调整模式
tiaozheng(moshi);  //调整时间
