[求助]位置约束怎么把多个symbol组合成一个component
在对DCM的位置进行约束时,提示:
ERROR ack:679 - Unable to obey design constraints (LOC=DCM_X2Y1) which require the combination of the following symbols into a single component: Dcm symbol "inst_dcm_clk/dcm_clk" (Output Signal = NULL) Gclk symbol "inst_dcm_clk/clk0_bufg_inst" (Output Signal = clk0_obuf) The constraint fragments target to conflict component type.   lease correct the design constraints accordingly.
小弟不太明白怎么做,请指教,3thx
