Performance Description
Number of poles: 1P, 2P, 3P, 4P
Rated current: 16A, 32A
Superiority
Control loop is triggered by the pulse signal to drive the main contact action. Different accessories can be assembled to achieve a variety of functions:
> Button control
> Central Control plus instructions
> Multi-level centralized control
> Step Control
Applications
Pulse relay to the remote control circuit:By pulse command
Multi-Point Control
Pulse relay circuit for controlling resistive loads (such as incandescent, low voltage halogen lamps, convection heaters) and the inductive load circuit (such as fluorescent tubes, discharge lamps)
参考资料来自传奇商城 |
