1、元件设备
三绕组变压器:three-column transformer ThrClnTrans
双绕组变压器:double-column transformer DblClmnTrans
电容器:Capacitor
并联电容器:shunt capacitor
电抗器:Reactor
母线:Busbar
输电线:TransmissionLine
发电厂:power plant
断路器:Breaker
刀闸(隔离开关):Isolator
分接头:tap
电动机:motor
2、状态参数
有功:active power
无功:reactive power
电流:current
容量:capacity
电压:voltage
档位:tap position
有功损耗:reactive loss
无功损耗:active loss
功率因数:power-factor |
