warning: period specification "TS_tx_clk"references the TNM group "tx_clk",which contains both pads and synchronous elements. The timing analyzer will ignore the pads for this specfication.You might want to use a qualifier(e.g. "FFS")on the TNM property to remove the pads from this group.
这个警告我应该如何应对呢?
谢谢 |
