在我完成原理图的连线后,在进行ERC检查时,出现了很多问题,可一直搞不定,有扰哪位GG JJ 帮小弟看看,小弟正在做毕设,急死人啦!不胜感激啊!!
具体错误如下: (而且同一类错误一大堆)
打包过程中 explore phsical
#1 WARNING(304) Device/Symbol check warning detected.
Symbol 'CK05' for device 'C' not found in PSMPATH or must be "dbdoctor"ed.
#2 WARNING(304) Device/Symbol check warning detected.
Symbol 'GKGA' for device 'C_VAR' not found in PSMPATH or must be "dbdoctor"ed.
进行ERC检查中 Pin Direction
#1 ERROR(211) No directional property data specified for pin A combination of INPUT_LOAD, OUTPUT_LOAD, OUTPUT_TYPE and BIDIRECTIONAL properties must be used to specify the pin direction. Pin name: E Instance: @MYPROJ_LIB.MYDESIGN(SCH_1)AGE1_I19@BJN.BC547A(CHIPS) Drawing: MYPROJ_LIB.MYDESIGN(SCH_1)AGE1AGEMYDESIGN(SCH_1)AGE1
Source\Drive 检查
#1 WARNING(205) No output on net Logical net name: @MYPROJ_LIB.GLBL(SCH_1):GND_POWER Error in both states (1 and 0)
#2 WARNING(205) No output on net Logical net name: @MYPROJ_LIB.MYDESIGN(SCH_1):OUTPUT Error in both states (1 and 0)
