单稳态继电器的型号
单稳态继电器的型号
单稳态继电器的型号
带LED灯系列
MY 2NJ 12Vac
MY 2NJ 24Vac DRM270524L 7760056064
MY 2NJ 48Vac DRM270548L 7760056065
MY 2NJ 100/110Vac DRM270615L 7760056066
MY 2NJ 110/120Vac DRM270615L 7760056066
MY 2NJ 200/220Vac DRM270730L 7760056067
MY 2NJ 220/240Vac DRM270730L 7760056067
MY 2NJ 6Vdc
MY 2NJ 12Vdc DRM270012L 7760056059
MY 2NJ 24Vdc DRM270024L 7760056060
MY 2NJ 48Vdc DRM270048L 7760056061
MY 2NJ 100/110Vdc DRM270110L 7760056062
MY 2NJ 200/220Vdc DRM270220L 7760056063
不带LED灯带测试杆系列
MY 2ZI2 12Vac
MY 2ZI2 24Vac DRM270524LT 7760056073
MY 2ZI2 50Vac DRM270548LT 7760056074
MY 2ZI2 100/110Vac DRM270615LT 7760056075
MY 2ZI2 110/120Vac DRM270615LT 7760056075
MY 2ZI2 200/220Vac DRM270730LT 7760056076
MY 2ZI2 220/240Vac DRM270730LT 7760056076
MY 2ZI2 6Vdc
MY 2ZI2 12Vdc DRM270012LT 7760056068
MY 2ZI2 24Vdc DRM270024LT 7760056069
MY 2ZI2 48Vdc DRM270048LT 7760056070
MY 2ZI2 100/110Vdc DRM270110LT 7760056071
MY 2ZI2 200/220Vdc DRM270220LT 7760056072
带LED灯带测试杆系列
MY 2ZI2N 12Vac
MY 2ZI2N 24Vac DRM270524LT 7760056073
MY 2ZI2N 48Vac DRM270548LT 7760056074
MY 2ZI2N 100/110Vac DRM270615LT 7760056075
MY 2ZI2N 110/120Vac DRM270615LT 7760056075
MY 2ZI2N 200/220Vac DRM270730LT 7760056076
MY 2ZI2N 220/240Vac DRM270730LT 7760056076
MY 2ZI2N 6Vdc
MY 2ZI2N 12Vdc DRM270012LT 7760056068
MY 2ZI2N 24Vdc DRM270024LT 7760056069
MY 2ZI2N 48Vdc DRM270048LT 7760056070
MY 2ZI2N 100/110Vdc DRM270110LT 7760056071
MY 2ZI2N 200/220Vdc DRM270220LT 7760056072
4路触点
不带LED灯系列
MY 4J 12Vac
MY 4J 24Vac DRM570524 7760056083
MY 4J 50Vac DRM570548 7760056084
MY 4J 100/110Vac DRM570615 7760056085
MY 4J 110/120Vac DRM570615 7760056085
MY 4J 200/220Vac DRM570730 7760056086
MY 4J 220/240Vac DRM570730 7760056086
MY 4J 6Vdc
MY 4J 12Vdc DRM570012 7760056078
MY 4J 24Vdc DRM570024 7760056079
MY 4J 48Vdc DRM570048 7760056080
MY 4J 100/110Vdc DRM570110 7760056081
MY 4J 200/220Vdc DRM570220 7760056082
带LED灯系列
MY 4NJ 12Vac
MY 4NJ 24Vac DRM570524L 7760056092
MY 4NJ 48Vac DRM570548L 7760056093
MY 4NJ 100/110Vac DRM570615L 7760056094
MY 4NJ 110/120Vac DRM570615L 7760056094
MY 4NJ 200/220Vac DRM570730L 7760056095
MY 4NJ 220/240Vac DRM570730L 7760056095
MY 4NJ 6Vdc
MY 4NJ 12Vdc DRM570012L 7760056087
MY 4NJ 24Vdc DRM570024L 7760056088
MY 4NJ 48Vdc DRM570048L 7760056089
MY 4NJ 100/110Vdc DRM570110L 7760056090
MY 4NJ 200/220Vdc DRM570220L 7760056091
不带LED灯带测试杆系列
MY 4ZI2 12Vac
MY 4ZI2 24Vac DRM570524LT 7760056101
MY 4ZI2 50Vac DRM570548LT 7760056102
MY 4ZI2 100/110Vac DRM570615LT 7760056103
MY 4ZI2 110/120Vac DRM570615LT 7760056103
MY 4ZI2 200/220Vac DRM570730LT 7760056104
MY 4ZI2 220/240Vac DRM570730LT 7760056104
MY 4ZI2 6Vdc
MY 4ZI2 12Vdc DRM570012LT 7760056096
MY 4ZI2 24Vdc DRM570024LT 7760056097
MY 4ZI2 48Vdc DRM570048LT 7760056098
MY 4ZI2 100/110Vdc DRM570110LT 7760056099
MY 4ZI2 200/220Vdc DRM570220LT 7760056100
不带LED灯带测试杆系列
MY 4ZI2N 12Vac
MY 4ZI2N 24Vac DRM570524LT 7760056101
MY 4ZI2N 48Vac DRM570548LT 7760056102
MY 4ZI2N 100/110Vac DRM570615LT 7760056103
MY 4ZI2N 110/120Vac DRM570615LT 7760056103
MY 4ZI2N 200/220Vac DRM570730LT 7760056104
MY 4ZI2N 220/240Vac DRM570730LT 7760056104
MY 4ZI2N 6Vdc
MY 4ZI2N 12Vdc DRM570012LT 7760056096
MY 4ZI2N 24Vdc DRM570024LT 7760056097
MY 4ZI2N 48Vdc DRM570048LT 7760056098
MY 4ZI2N 100/110Vdc DRM570110LT 7760056099
MY 4ZI2N 200/220Vdc DRM570220LT 7760056100
带二极管保护输入系列
MY2-D 24Vdc DRM270024LD 7760056077
MY4-D 24Vdc DRM570024LD 7760056105
MY2N-D2 DRM270024LD 7760056077
MY4N-D2 DRM570024LD 7760056105
参考资料来自传奇电器
