皮尔兹PILZ电磁继电器774196 Terminal block filter 2 、774300 PNOZ X1 24VAC/DC 3n/o 1n/c 、774303 PNOZ X2 24VAC/DC 2n/o 、774304 PNOZ X2C 24VAC/DC 2n/o
774305 PNOZ X2.1C 24VAC/DC 2n/o 、774306 PNOZ X2.1 24VAC/DC 2n/o 、774309 PNOZ X3.2 230VAC 24VDC 3n/o 1n/c 1so
774310 PNOZ X3 24VAC 24VDC 3n/o 1n/c 1so 、774311 PNOZ X3 42VAC 24VDC 3n/o 1n/c 1so 、774312 PNOZ X3 48VAC 24VDC 3n/o 1n/c 1so
774314 PNOZ X3 110VAC 24VDC 3n/o 1n/c 1so 、774315 PNOZ X3 115VAC 24VDC 3n/o 1n/c 1so 、774316 PNOZ X3 120VAC 24VDC 3n/o 1n/c 1so
774318 PNOZ X3 230VAC 24VDC 3n/o 1n/c 1so 、774319 PNOZ X3 240VAC 24VDC 3n/o 1n/c 1so 、774321 PNOZ X3.1 230VAC 24VDC 3n/o 1n/c 1so
774322 PNOZ X3.1 240VAC 24VDC 3n/o 1n/c 1so 、774420 PDZK WDP3-01 1000/20 24 Vdc 、774434 P2HZ X1 110VAC 3n/o 1n/c
774435 P2HZ X1 115VAC 3n/o 1n/c 、774436 P2HZ X1 120VAC 3n/o 1n/c 、774438 P2HZ X1 230VAC 3n/o 1n/c
774439 P2HZ X1 240VAC 3n/o 1n/c 、774500 PNOZ XV2 30/24VDC 2n/o 2n/o t 、774502 PNOZ XV2 3/24VDC 2n/o 2n/o t
774504 PNOZ XV2 0.5/24VDC 2n/o 2n/o fix 、774505 PNOZ XV2 3/24VDC 2n/o 2n/o fix 、774506 PNOZ XV2 10/24VDC 2n/o 2n/o fix
774508 PNOZ XV2 300/24VDC 2n/o 2n/o t 、774510 PNOZ XV2.1 30/24VAC 24VDC 2n/o 2n/o t 、774515 PNOZ XV2.1 30/120VAC 24VDC 2n/o 2n/o t
774516 PNOZ XV2.1 30/230VAC 24VDC 2n/o 2n/o t 、774517 PNOZ X2.4V 1/24VDC 4n/o 1so fix 、774520 PNOZ XV2.1 3/24VAC 24VDC 2n/o 2n/o t
774524 PNOZ XV2.1 3/115VAC 24VDC 2n/o 2n/o t 、774525 PNOZ XV2.1 3/120VAC 24VDC 2n/o 2n/o t 、774526 PNOZ XV2.1 3/230VAC 24VDC 2n/o 2n/o t
774530 PNOZ XV3.1 30/24VDC 3n/o 1n/c 2n/o t 、774532 PNOZ XV3.1 3/24VDC 3n/o 1n/c 2n/o t 、774534 PNOZ XV3.1 0.5/24 Vdc 3n/o 1n/c 2n/o fix
774536 PNOZ XV2.1 0.5/230 Vac 24 Vdc 2n/o 2n/o f 、774538 PNOZ XV3.1 300/24VDC 3n/o 1n/c 2n/o t 、774540 PNOZ XV3 30/24VDC 3n/o 2n/o t
774541 PNOZ XV3 300/24VAC 3n/o 2n/o t 、774542 PNOZ XV3 3/24VDC 3n/o 2n/o t 、774544 PNOZ XV3 0.5/24VDC 3n/o 2n/o t fix
774545 PNOZ XV3 3/24VDC 3n/o 2n/o t fix 、774546 PNOZ XV2.1 3/230 Vac/24 Vdc 2n/o 2n/o fix 、774547 PNOZ XV3 10/24VDC 3n/o 2n/o t fix
774548 PNOZ XV3 300/24VDC 3n/o 2n/o t 、774549 PNOZ X13 24VDC 5n/o 1n/c 、774550 PNOZ XV2.1 30/24-240VACDC 2n/o 2n/o t
774552 PNOZ XV2.1 3/24-240VACDC 2n/o 2n/o t 、774554 PNOZ XV2.1 0.5/24-240 VacDC 2n/o 2n/o fix 、774558 PNOZ XV2.1 300/24-240VACDC 2n/o 2n/o t
774560 PNOZ XHCV 0,7/24VDC 2n/o fix 、774573 MOD PS 85-265 Vac 、774578 PPS 100-240VAC / 24VDC 、774580 PZE X4V 0,5/24VDC 4n/o fix
774581 PZE X4V 1/24VDC 4n/o fix 、774582 PZE X4V 2/24VDC 4n/o fix 、774583 PZE X4V 3/24VDC 4n/o fix 、774584 PZE X4V8 24VDC 4n/o
774585 PZE X4 24VDC 4n/o 、774586 PZE X4V 0,7/24VDC 4n/o fix 、774590 PZE X5V 3/48VDC 5n/o fix
774592 PZE X5V 1.5/24VDC 5n/o fix 、774593 PZE X5V 3/24VDC 5n/o fix 、774595 PZE X5 24VDC 5n/o 、774601 PNOZ X9 42VAC 24VDC 7n/o 2n/c 2so
774605 PNOZ X9 100-120VAC 24VDC 7n/o 2n/c 2so 、774606 PNOZ X9 200-230VAC 24VDC 7n/o 2n/c 2so 、774607 PNOZ X2.2 24VAC/DC 2n/o
774608 PNOZ X9 200VAC 24VDC -774606 、774609 PNOZ X9 24VAC 24VDC 7n/o 2 n/c 2so 、774610 PNOZ XV3.1 30/24-240VACDC 3no 1nc 2no t
774612 PNOZ XV3.1 3/24-240VACDC 3no 1nc 2no t 、774618 PNOZ XV3.1 300/24-240VACDC 3no 1nc 2no t |
