ucosII移植问题。
ucosII移植问题。
各位大侠,
   在移植的时候,报错:file stack overflow (no recursive) 是什么意思?
多多指教!!
Warning : C1020: Incompatible type to previous declaration (found 'void *(*) (void (*)(void *),void *,unsigned char *,unsigned int )',
expected 'unsigned char *(*) (void (*)(void *),void *,unsigned char *,unsigned int )')
OS_CPU_C.C line 10
C1440: This is causing previous message 1020
ucos_ii.h line 823
Warning : C1801: Implicit parameter-declaration
OS_CPU_C.C line 41
Warning : C1420: Result of function-call is ignored
OS_CPU_C.C line 41
C12053: Stack-pointer change not in debugging-information
OS_CPU_C.C line 63
OS_CPU_C.C line 90
OS_CPU_C.C line 107
Warning : C5917: Removed dead assignment
OS_CPU_C.C line 189
OS_CPU_C.C line 265
L1923: File G:\ucos yizhi\test6\test6\test6_Data\Simulator\ObjectCode\OS_CPU_C.C.o has no DWARF debug inf
这是什么意思啊?怎么解决啊?
多多指教!!
使用ucos_ii.h头文件的文件中有些函数估计没有到头文件中预定义
另外,OS_CPU_C.C的debug信息没有加上,找到文件最后一栏的绿色小甲虫,在那里加上黑点。编译再看看,有没有其他的warning
