电压继电器的技术参数及型号
电压继电器的技术参数及型号
电压继电器的技术参数
  •   ● 电压测量误差范围:±0.5[%]/F.S
      ● 被测电压的频率为50/60Hz可选。
      ● 响应时间可调:30ms~3s。
      ● 输出继电器触点为1常开1常闭(带公共端),容量为7A/250VAC(或7A/30VDC)(阻性负载)。
      ● 标准辅助工作电源:75~265VAC或70~360VDC。(其他电源可定制)
      ● 使用环境-20~55℃,相对湿度10~85[%]。
      ● 功耗:≤4VA
      ● 安装尺寸: 外形尺寸:96 mm×48 mm×112mm, 开孔尺寸:91mm×45mm
  • 电压继电器的型号
  • BY-4A,BY-2A,BY-4E,BZY-1,BFY-10A,BFY-11A,BFY-12A,BFY-13A,BGDJ-10,BGDJ-11/1,BGDJ-12/1,BGDJ-13/1,BGDJ-11/2,BGDJ-12/2,BGDJ-13/2,DJ-111,DJ-121,DJ-131,DJ-131/60C,DJ-131/60CN,DJ-112,DJ-122,DJ-132,DY-21C,DY-22C,DY-23C,DY-24C,DY-25C,DY-21C/60C,DY-22C/60C,DY-23C/60C,DY-24C/60C,DY-25C/60C,DY-26C,DY-27C,DY-28C,DY-29C,DY-21D,DY-22D,DY-23D,DY-24D,DY-21D/60C,DY-22D/60C,DY-23D/60C,DY-24D/60C,DY-25D,DY-26D,DY-27D,DY-28D,DY-29D,DY-21CE,DY-22CE,DY-23CE,DY-24CE,DY-21CE/60C,DY-22CE/60C,DY-23CE/60C,DY-24CE/60C,DY-26CE,DY-27CE,DY-28CE,DY-29CE,DY-31,DY-32,DY-33,DY-34,DY-32/60C,DY-35,DY-36,DY-37,DY-38,DY-2,DY-3,DY-4,DY-5,LY-1A,LZY-2,LLY-1,LLY-2,LLY-3,LY-31,LY-32,LY-33,LY-34,LY-35,LY-36,LY-37,JCDY-2A/220V,JCDY-2A/110V,JCDY-2A/48V,JCDY-2/G220V,JCDY-2/G110V,JCDY-2/G48V,JCDY-2/Q220V,JCDY-2/Q110V,JCDY-2/Q48V,JY-40A,JY-40B,JY-40C,JY-40UA,JY-40UB,JY-40UC,JY-40A/1a,JY-40A/2a,JY-40A/3a,JY-40A/4a,JY-40A/5a,JY-40A/6a,JY-40C/1a,JY-40C/2a,JY-40C/3a,JY-40C/4a,JY-40C/5a,JY-40C/6a,JY-40B/1a,JY-40B/2a,JY-40B/3a,JY-40B/4a,JY-40B/5a,JY-40B/6a,JY-40UA/1a,JY-40UA/2a,JY-40UA/3a,JY-40UA/4a,JY-40UA/5a,JY-40UA/6a,JY-40UB/1a,JY-40UB/2a,JY-40UB/3a,JY-40UB/4a,JY-40UB/5a,JY-40UB/6a,JY-40UC/1a,JY-40UC/2a,JY-40UC/3a,JY-40UC/4a,JY-40UC/5a,JY-40UC/6a,JY-40A/1b,JY-40A/2b,JY-40A/3b,JY-40A/4b,JY-40A/5b,JY-40A/6b,JY-40B/1b,JY-40B/2b,JY-40B/3b,JY-40B/4b,JY-40B/5b,JY-40B/6b,JY-40C/1b,JY-40C/2b,JY-40C/3b,JY-40C/4b,JY-40C/5b,JY-40C/6b,JY-40UA/1b,JY-40UA/2b,JY-40UA/3b,JY-40UA/4b,JY-40UA/5b,JY-40UA/6b,JY-40UB/1b,JY-40UB/2b,JY-40UB/3b,JY-40UB/4b,JY-40UB/5b,JY-40UB/6b,JY-40UC/1b,JY-40UC/2b,JY-40UC/3b,JY-40UC/4b,JY-40UC/5b,JY-40UC/6b,JY-40A/1c,JY-40A/2c,JY-40A/3c,JY-40A/4c,JY-40A/5c,JY-40A/6c,JY-40B/1c,JY-40B/2c,JY-40B/3c,JY-40B/4c,JY-40B/5c,JY-40B/6c,JY-40C/1c,JY-40C/2c,JY-40C/3c,JY-40C/4c,JY-40C/5c,JY-40C/6c,JY-40UA/1c,JY-40UA/2c,JY-40UA/3c,JY-40UA/4c,JY-40UA/5c,JY-40UA/6c,JY-40UB/1c,JY-40UB/2c,JY-40UB/3c,JY-40UB/4c,JY-40UB/5c,JY-40UB/6c,JY-40UC/1c,JY-40UC/2c,JY-40UC/3c,JY-40UC/4c,JY-40UC/5c,JY-40UC/6c,JY-40A/1d,JY-40A/2d,JY-40A/3d,JY-40A/4d,JY-40A/5d,JY-40A/6d,JY-40B/1d,JY-40B/2d,JY-40B/3d,JY-40B/4d,JY-40B/5d,JY-40B/6d,JY-40C/1d,JY-40C/2d,JY-40C/3d,JY-40C/4d,JY-40C/5d,JY-40C/6d,JY-40UA/1d,JY-40UA/2d,JY-40UA/3d,JY-40UA/4d,JY-40UA/5d,JY-40UA/6d,JY-40UB/1d,JY-40UB/2d,JY-40UB/3d,JY-40UB/4d,JY-40UB/5d,JY-40UB/6d,JY-40UC/1d,JY-40UC/2d,JY-40UC/3d,JY-40UC/4d,JY-40UC/5d,JY-40UC/6d,JY-40A/1e,JY-40A/2e,JY-40A/3e,JY-40A/4e,JY-40A/5e,JY-40A/6e,JY-40B/1e,JY-40B/2e,JY-40B/3e,JY-40B/4e,JY-40B/5e,JY-40B/6e,JY-40C/1e,JY-40C/2e,JY-40C/3e,JY-40C/4e,JY-40C/5e,JY-40C/6e,JY-40UA/1e,JY-40UA/2e,JY-40UA/3e,JY-40UA/4e,JY-40UA/5e,JY-40UA/6e,JY-40UB/1e,JY-40UB/2e,JY-40UB/3e,JY-40UB/4e,JY-40UB/5e,JY-40UB/6e,JY-40UC/1e,JY-40UC/2e,JY-40UC/3e,JY-40UC/4e,JY-40UC/5e,JY-40UC/6e,JY-3/1,JY-3/2,JY-3H/2,JY-11A,JY-11B,JY-21A,JY-21B,JY-31A,JY-31B,JY-12A,JY-12B,JY-22A,JY-22B,JY-32A,JY-32B,JD-1A,JD-1B,JD-1C,JD-2A,JD-2B,JD-2C,JY-8-11A,JY-8-11B,JY-8-11C,JY-8-12A,JY-8-12B,JY-8-12C,JY-8-21A,JY-8-21B,JY-8-21C,JY-8-22A,JY-8-22B,JY-8-22C,JY-8-31A,JY-8-31B,JY-8-31C,JY-8-32A,JY-8-32B,JY-8-32C
