相序继电器型号种类
相序继电器型号种类
一般情况下,电动机工作的接线顺序是有规定的,如果由于某种原因,导致相序发生错乱,电动机将无法正常工作甚至损坏。三相电源中有A相、B相、C相,假如按ABC相序电源接入电动机,电动机是正转,那么按ACB相序电源接入电动机,电动机就是反转了。为了防止电动机反转,就加入了相序继电器,来防止进来电源相序反相,造成电动机反转。
相序继电器的型号
DD-11,DD-11/40,DD-11Q/40,DD-11/50,DD-11Q/50,DD-11/60,DD-11Q/60,DD-1,DD-1/40,DD-1/50,DD-1/60,LD-3,ZD-6,DT-1,DT-1/90,DT-1/120,DT-1/130,DT-1/160,DT-1/200,DT-13,DT-13/90,DT-13Q/90,DT-13/120,DT-13Q/120,DT-13/160,DT-13Q/160,DT-13/200,DT-13Q/200,DT-13/254,DT-13Q/254,BT-1B,BT-1B/200,BT-1B/160,BT-1B/130,BT-1B/120,BT-1B/90,BT-1B/0.2,BXX-2,DLS-5,DLS-5/1,DLS-5/2,DLS-5/3,DLS-10B,DLS-11B,DLS-12B,DLS-20H,DLS-30A,DLS-31A,DLS-32A,DLS-33A,DLS-34A,DLS-35A,DLS-500A,DLS-40,DLS-41,DLS-41/6-6,DLS-41/7-5,DLS-41/8-4,DLS-41/9-3,DLS-41/10-2,DLS-42,DLS-42/6-4,DLS-42/7-3,DLS-42/8-2,DLS-42/9-1,DLS-42/5-5,DLS-43,DLS-43/6-4,DLS-43/7-3,DLS-43/8-2,DLS-43/9-1,DLS-43/5-5,DLS-44,DLS-44/6-2,DLS-44/7-1,DLS-44/8,DLS-44/4-4,DLS-44/5-3,DLS-41F,DLS-41F/10-2,DLS-41F/9-3,DLS-41F/8-4,DLS-41F/7-5,DLS-41F/6-6,DLS-45F,DLS-45F/10-2,DLS-45F/9-3,DLS-45F/8-4,DLS-45F/7-5,DLS-45F/6-6,DLS-42F,DLS-42F/9-1,DLS-42F/8-2,DLS-42F/7-3,DLS-42F/6-4,DLS-42F/5-5,DLS-46F,DLS-46F/9-1,DLS-46F/8-2,DLS-46F/7-3,DLS-46F/6-4,DLS-46F/5-5,DLS-43F,DLS-43F/9-1,DLS-43F/8-2,DLS-43F/7-3,DLS-43F/6-4,DLS-43F/5-5,DLS-44F,DLS-44F/6-2,DLS-44F/7-1,DLS-44F/8,DLS-44F/4-4,DLS-44F/5-3,JSW-8-30
