请教大家:
我的板子上用的芯片是MC9S12D64,但BDM-multilink无法下载程序。只能硬件仿真。察看codewarrior的command窗口,有一段似乎异常:
MCU clock speed: 1544000 Hz Block Module Name Address Range Status 0 EEPROM 1000 - 17FF Blank - Unselected 1 FLASH_4000 4000 - 7FFF Blank - Unselected 2 FLASH_C000 C000 - FFFF Programmed - Unselected 3 PAGED 3C8000 -3FBFFF Programmed - Unselected
The UNPROTECT command is not available for the EEPROM flash module => Skipped.
The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
The UNPROTECT command is not available for the PAGED flash module => Skipped.
不知为何跳过以上的命令,是否由此导致下载不成功? |
