LED在光输出、能效及成本方面得到了全面改善,同时具备了小巧、低压工作及环保等众多优势,应用范围也在不断拓宽。未来,LED照明在通用照明、LCD背光、汽车照明等领域的增长前景尤为可观。安森美半导体提供丰富的LED驱动器产品,可满足各种LED照明应用需求。
方案特性:
LEDs are replacing traditional incandescent and halogen lighting sources in architectural, industrial, residential and the transportation lighting. The key challenge in powering LED’s is providing a constant current source. The evaluation board for the NCP3065/NCV3065 can be easily configured for a variety of constant current buck and boost
LED driver applications.
It describes a DC−DC converter circuits that can easily be configured to drive LEDs at several different output currents and can be configured for either AC or DC input. The NCP3065/NCV3065 can be configured in a several driver topologies to a drive string of LEDs: be it traditional low power LEDs or high brightness high power LEDs such as the Lumileds Luxeona K2 and Rebel series, the CREE XLAMPa 4550 or XR series, the OSRAM OSTARa, TopLEDa and Golden Dragona.
方案原理图:
参照PCB图: |
