# vsim work.BCHtop # Loading work.BCHtop # ** Error: (vsim-3033) BCHtop_translate.v(32): Instantiation of 'X_BUF' failed. The design unit was not found. # Region: /BCHtop # Searched libraries: # work # ** Error: (vsim-3033) BCHtop_translate.v(35): Instantiation of 'X_ZERO' failed. The design unit was not found. # Region: /BCHtop # Searched libraries: # work # ** Error: (vsim-3033) BCHtop_translate.v(38): Instantiation of 'X_OPAD' failed. The design unit was not found. # Region: /BCHtop # Searched libraries: # work # ** Error: (vsim-3033) BCHtop_translate.v(43): Instantiation of 'X_TRI' failed. The design unit was not found. # Region: /BCHtop # Searched libraries: # work # ** Error: (vsim-3033) BCHtop_translate.v(47): Instantiation of 'X_INV' failed. The design unit was not found. # Region: /BCHtop # Searched libraries: # work # Error loading design |
