这样还是不行,我又写了这样一个vector文件
#pragma CODE_SEG __NEAR_SEG NON_BANKED /* Interrupt section for this module. Placement will be in NON_BANKED area. */
__interrupt void Cpu_Interrupt(void)
__interrupt void Cpu_Interrupt1(void)
#pragma CODE_SEG DEFAULT /* Change code section to DEFAULT. */
typedef void (*near tIsrFunc)(void);
const tIsrFunc _vect[] @0xFF80 = { /* Interrupt table */
Cpu_Interrupt, /* 0 Default (unused) interrupt */
Cpu_Interrupt, /* 1 Default (unused) interrupt */
Cpu_Interrupt, /* 2 Default (unused) interrupt */
Cpu_Interrupt, /* 3 Default (unused) interrupt */
Cpu_Interrupt, /* 4 Default (unused) interrupt */
Cpu_Interrupt, /* 5 Default (unused) interrupt */
Cpu_Interrupt, /* 6 Default (unused) interrupt */
Cpu_Interrupt, /* 7 Default (unused) interrupt */
Cpu_Interrupt, /* 8 Default (unused) interrupt */
Cpu_Interrupt, /* 9 Default (unused) interrupt */
Cpu_Interrupt, /* 10 Default (unused) interrupt */
Cpu_Interrupt, /* 11 Default (unused) interrupt */
Cpu_Interrupt, /* 12 Default (unused) interrupt */
Cpu_Interrupt, /* 13 Default (unused) interrupt */
Cpu_Interrupt, /* 14 Default (unused) interrupt */
Cpu_Interrupt, /* 15 Default (unused) interrupt */
Cpu_Interrupt, /* 16 Default (unused) interrupt */
Cpu_Interrupt, /* 17 Default (unused) interrupt */
Cpu_Interrupt, /* 18 Default (unused) interrupt */
Cpu_Interrupt, /* 19 Default (unused) interrupt */
Cpu_Interrupt, /* 20 Default (unused) interrupt */
Cpu_Interrupt, /* 21 Default (unused) interrupt */
Cpu_Interrupt, /* 22 Default (unused) interrupt */
Cpu_Interrupt, /* 23 Default (unused) interrupt */
Cpu_Interrupt, /* 24 Default (unused) interrupt */
Cpu_Interrupt, /* 25 Default (unused) interrupt */
Cpu_Interrupt, /* 26 Default (unused) interrupt */
Cpu_Interrupt, /* 27 Default (unused) interrupt */
Cpu_Interrupt, /* 28 Default (unused) interrupt */
Cpu_Interrupt, /* 29 Default (unused) interrupt */
Cpu_Interrupt, /* 30 Default (unused) interrupt */
Cpu_Interrupt, /* 31 Default (unused) interrupt */
Cpu_Interrupt, /* 32 Default (unused) interrupt */
Cpu_Interrupt, /* 33 Default (unused) interrupt */
Cpu_Interrupt, /* 34 Default (unused) interrupt */
Cpu_Interrupt, /* 35 Default (unused) interrupt */
Cpu_Interrupt, /* 36 Default (unused) interrupt */
Cpu_Interrupt, /* 37 Default (unused) interrupt */
Cpu_Interrupt, /* 38 Default (unused) interrupt */
Cpu_Interrupt, /* 39 Default (unused) interrupt */
Cpu_Interrupt, /* 40 Default (unused) interrupt */
Cpu_Interrupt, /* 41 Default (unused) interrupt */
Cpu_Interrupt, /* 42 Default (unused) interrupt */
Cpu_Interrupt, /* 43 Default (unused) interrupt */
Cpu_Interrupt, /* 44 Default (unused) interrupt */
Cpu_Interrupt, /* 45 Default (unused) interrupt */
Cpu_Interrupt, /* 46 Default (unused) interrupt */
Cpu_Interrupt, /* 47 Default (unused) interrupt */
Cpu_Interrupt, /* 48 Default (unused) interrupt */
Cpu_Interrupt, /* 49 Default (unused) interrupt */
Cpu_Interrupt, /* 50 Default (unused) interrupt */
Cpu_Interrupt, /* 51 Default (unused) interrupt */
Cpu_Interrupt, /* 52 Default (unused) interrupt */
Cpu_Interrupt, /* 53 Default (unused) interrupt */
Cpu_Interrupt, /* 54 Default (unused) interrupt */
Cpu_Interrupt, /* 55 Default (unused) interrupt */
Cpu_Interrupt, /* 56 Default (unused) interrupt */
Cpu_Interrupt, /* 57 Default (unused) interrupt */
Cpu_Interrupt, /* 58 Default (unused) interrupt */
Cpu_Interrupt, /* 59 Default (unused) interrupt */
Cpu_Interrupt, /* 60 Default (unused) interrupt */
Cpu_Interrupt1, /* 61 Default (unused) interrupt */
Cpu_Interrupt, /* 62 Default (unused) interrupt */
_Startup /* Reset vector */
但是不管我把 Cpu_Interrupt1 放在那个中断向量处,调试器都回出现上面图中的情况,并且代码停在
中断函数处 |
