[求助]L1108 Link 问题
[求助]L1108 Link 问题
 我编了一个程序(PT0输出比较),初始化程序如下,
void InitSystem (void)
     DDRA =0xFF;    //PORTA set as output;
     TIOS =0x81;      // InputCapture or OutputCompare choice;
     TSCR1=0X80;
     TSCR2=0X0F;    // The cloclk moduls choice : 1/128;
     TCTL1= 0X00;
     TCTL2=0X00;
     TC0=  0xffff;    //  input compare value;
     TC7=0XFFFF;
     TIE=  0x01;    // enable interruption PT0;
     TIOS=0X01;
中断地址为0xffee,编译后显示LINK ERROR :L1108: Initializing of Vector TimeInt failed because of over- or underflow of vector value
Link Error   : Link failed
  望不啬赐教,小生这厢有礼了!
孤独是我的个性 飞翔是我的梦想
中断向量写的不对,或者中断函数存放的段有问题
中断函数要放在Non_banked区间段
