你仔细研究下这段代码就清楚了.poll select之类的,都差不多.
int do_select(int n, fd_set_bits *fds, long *timeout)
poll_table table, *wait;
int retval, i, off;
long __timeout = *timeout;
read_lock(¤t->files->file_lock);
retval = max_select_fd(n, fds);
read_unlock(¤t->files->file_lock);
if (retval < 0)
return retval;
n = retval;
poll_initwait(&table);
wait = &table;
if (!__timeout)
wait = NULL;
retval = 0;
for (;;) {
set_current_state(TASK_INTERRUPTIBLE);
for (i = 0 ; i < n; i++) {
unsigned long bit = BIT(i);
unsigned long mask;
struct file *file;
off = i / __NFDBITS;
if (!(bit & BITS(fds, off)))
continue;
file = fget(i);
mask = POLLNVAL;
if (file) {
mask = DEFAULT_POLLMASK;
if (file->f_op && file->f_op->poll)
mask = file->f_op->poll(file, wait);
fput(file);
if ((mask & POLLIN_SET) && ISSET(bit, __IN(fds,off))) {
SET(bit, __RES_IN(fds,off));
retval++;
wait = NULL;
if ((mask & POLLOUT_SET) && ISSET(bit, __OUT(fds,off))) {
SET(bit, __RES_OUT(fds,off));
retval++;
wait = NULL;
if ((mask & POLLEX_SET) && ISSET(bit, __EX(fds,off))) {
SET(bit, __RES_EX(fds,off));
retval++;
wait = NULL;
wait = NULL;
if (retval || !__timeout || signal_pending(current))
break;
if(table.error) {
retval = table.error;
break;
__timeout = schedule_timeout(__timeout);
current->state = TASK_RUNNING;
poll_freewait(&table);
* Up-to-date the caller timeout.
*timeout = __timeout;
return retval;
循环调用你设备的poll函数,如果你的状态没有改变,就返回0,所有它监测的设备都返回0,那么break需要的条件不会满足(retval 始终是 0).那么就不会返回,而会去调度走.
这个函数和sleep_on的实现其实比较类似,可以理解为集体睡眠函数,唤醒还是用wake_up. |
51 c8051f(f020,f040) msp430 arm(2410,2510) fpga(xc3s4000) dsp(5116 dm642) keilc vc++ matlab linux protel Ten_layerPCB mpegx h.26x Rscode Turbocode ofdm VideoBroadcasting ldpc_code(now!) |
