向大家请教一个问题:
'timescale 1ns/1ns 'include "./compare.v" module t; reg a,b; wire equal; initial begin a=0; b=0; #100 a=0;b=1; #100 a=1;b=1; #100 a=1;b=0; #100 a=0;b=0; #100 $stop; end compare m(.equal(equal),.a(a),.b(b)); endmodule
是用Verilog HDL编的,在modelsim6.0里为什么不能仿真呢?这里的compare.v模块文件己经写好,且编译过了没有问题.
modelsim6.0的出错提示是:
** Error: F:/t_compare.v(1): near "'t": Illegal base specifier in numeric constant. ** Error: F:/t_compare.v(1): near "'t": expecting: LIBRARY CONFIG ** Error: F:/t_compare.v(1): Expecting numeric digits. ** Error: F:/t_compare.v(2): near "'i": Illegal base specifier in numeric constant. ** Error: F:/t_compare.v(2): Expecting numeric digits.
是什么意思啊?我怎么也弄不懂.
谢谢各位了! |
