These devices consist of two independent voltage comparators that are designed to operate from a single power supply over a wide range of voltages. Operation from dual supplies also is possible as long as the difference between the two supplies is 2 V to 36 V, and VCC is at least 1.5 V more positive than the input common-mode voltage. Current drain is independent of the supply voltage. The outputs can be connected to other open-collector outputs to achieve wired-AND relationships. The LM193 is characterized for operation from –55°C to 125°C. The LM293 and LM293A are characterized for operation from –25°C to 85°C. The LM393 and LM393A are characterized for operation from 0°C to 70°C. The LM2903 is characterized for operation from –40°C to 125°C. Features
Single Supply or Dual Supplies Wide Range of Supply Voltage…2 V to 36 V Max Rating . . . 2 V to 36 V Tested to 30 V… Non-V Devices Tested to 32 V… V-Suffix Devices Low Supply-Current Drain Independent of Supply Voltage . . . 0.4 mA Typ Per Comparator Low Input Bias Current . . . 25 nA Typ Low Input Offset Current …3 nA Typ (LM193) Low Input Offset Voltage …2 mV Typ Common-Mode Input Voltage Range Includes Ground Differential Input Voltage Range Equal to Maximum-Rated Supply Voltage . . . ±36 V Low Output Saturation Voltage Output Compatible With TTL, MOS, and CMOSArticle Sources: Texas Instruments ![](http://www.eccn.com/uploads/product/201302/2013022503371432.jpg)
