module SRAM_16Bit_512K(// Host Data oDATA,iDATA,iADDR, iWE_N,iOE_N, iCE_N,iRST_N, iUB_N,iLB_N, // SRAM SRAM_DQ, SRAM_ADDR, SRAM_UB_N, SRAM_LB_N, SRAM_WE_N, SRAM_CE_N, SRAM_OE_N ); // Host Side input [15:0] iDATA; output [15:0] oDATA; input [17:0] iADDR; input iWE_N,iOE_N; input iCE_N,iRST_N; input iUB_N,iLB_N; // SRAM Side inout [15:0] SRAM_DQ; output [17:0] SRAM_ADDR; output SRAM_UB_N, SRAM_LB_N, SRAM_WE_N, SRAM_CE_N, SRAM_OE_N;
assign SRAM_DQ = SRAM_WE_N ? 16'hzzzz : iDATA; assign oDATA = SRAM_DQ; assign SRAM_ADDR = iADDR; assign SRAM_WE_N = iWE_N; assign SRAM_OE_N = iOE_N; assign SRAM_CE_N = iCE_N; assign SRAM_RST_N = iRST_N; assign SRAM_UB_N = SRAM_UB_N; assign SRAM_LB_N = SRAM_LB_N;
endmodule
以上是一个sram的与niosII接口控制器,但是当我在ide环境下添加新元件时,最后不知道input iUB_N,iLB_N;两个引脚singal Type定为什么,它的作用是对sram的访问采用8位或16位
为低有效。 |
