Linux 系统命令及其使用详解(大全) 30
名称:expr
  使用权限:所有使用者
  ### 字串长度
shell>> expr length "this is a test"
14
  ### 数字商数
shell>> expr 14 % 9
5
  ### 从位置处抓取字串
shell>> expr substr "this is a test" 3 5
is is
  ### 数字串
only the first character
shell>> expr index "testforthegame" e
2
  ### 字串真实重现
shell>> expr quote thisisatestformela
thisisatestformela
  名称: tr
  ### 1.比方说要把目录下所有的大写档名换为小写档名?
  似乎有很多方式,"tr"是其中一种
#!/bin/sh
dir="/tmp/testdir";
files=`find $dir -type f`;
for i in $files
do
dir_name=`dirname $i`;
ori_filename=`basename $i`
new_filename=`echo $ori_filename | tr [:upper:] [:lower:]` > /dev/null;
#echo $new_filename;
mv $dir_name/$ori_filename $dir_name/$new_filename
done
  ### 2.自己试验中
...lowercase to uppercase
tr abcdef...[del] ABCDE...[del]
tr a-z A-Z
tr [:lower:] [:upper:]
shell>> echo "this is a test" | tr a-z A-Z > www
shell>> cat www
THIS IS A TEST
  ### 3.去掉不想要的字串
  shell>> tr -d this ### 去掉有关
t.e.s.t
this
man
man
test
e
  ### 4.取代字串
shell>> tr -s "this" "TEST"
this
TEST
th
TE
