哪位高人有fifo的VHDL代码阿?实际烧到片子里能运行通过的!
我是新手,在网上看到一些代码,都不太对,需要修改,我自己参考着编了一个,仿真通过,但还是烧到片子里不能运行,无输出,希望哪位高人指点一下!给我一个验证过的完全正确的代码让我参考一下!谢谢了,好长时间都没解决,非常郁闷!
我把我的代码附在这里,同时希望批评指正!
library ieee; use ieee.std_logic_1164.all; entity fifo is
port ( clkwr,clkrd,wr,rd,cs:in std_logic; din :in std_logic_vector( 0 to 7); dout ut std_logic_vector( 0 to 7); full,empty ut std_logic ); end fifo;
architecture fifo_arch of fifo is type memory is array (0 to 3) of std_logic_vector( 0 to 7); signal ram:memory; signal wp: integer range 0 to 7 :=0; signal rp: integer range 0 to 7 :=0; signal in_full,in_empty:std_logic; begin
process(clkwr,cs) -----------------------------------------write begin if rising_edge(clkwr) and cs='0' then if (wr='0' and in_full='0') then ram(wp)<=din; end if; end if; end process;
process(clkrd) -----------------------------------------read begin if rising_edge(clkrd) and cs='0' then if (rd='0' and in_empty='0') then dout<=ram(rp); else dout<="ZZZZZZZZ"; end if; end if; end process;
process(clkwr) -----------------------------------------write hand begin if rising_edge(clkwr) and cs='0' then if (wr='0' and in_full='0') then if(wp=3) then wp<=0; else wp<=wp+1; end if; end if; end if; end process;
process(clkrd) ------------------------------------------------read hand begin if rising_edge(clkrd) and cs='0' then if (rd='0' and in_empty='0') then if(rp=3) then rp<=0; else rp<=rp+1; end if; end if; end if; end process; process(clkrd) -------------------------------------------------empty begin if falling_edge(clkrd) and cs='0' then if ((wp=rp) or (wp=rp+1) or ((wp=0) and (rp=3)))then in_empty<='1'; else in_empty<='0'; end if; end if; end process;
process(clkwr) --------------------------------------------------full begin if falling_edge(clkwr) and cs='0' then if ((rp=wp+1)or ((wp=3) and (rp=0))) then in_full<='1'; else in_full<='0'; end if; end if; end process;
full<=in_full; empty<=in_empty;
end fifo_arch;
