提高NIOS频率的技巧
提高NIOS频率的技巧
Turning on some optimizations in Quartus II may help increase it. Here are some you may want to try:
a.) Change the optimization technique to Speed
• Click Assignments -> Settings
• Select Analysis & Synthesis Settings
• For Optimization Technique, select Speed
b.) Turn on one-hot state machine processing
• For State Machine Processing, select One-Hot
c.) Turn off Multiplexer Restructuring
• For Restructure Multiplexers, select Off
d.) Turn on Physical Synthesis in the Fitter
• Expand Fitter Settings by clicking the + symbol next to it.
• Select Physical Synthesis Optimizations
• Check Perform physical synthesis for combinational logic
• Check Perform register duplication
• Check Perform register retiming
• Select Normal for Physical synthesis effort
不要让nios跑在时序分析报告的最高频率之上,否则系统可能不稳定,甚至不能下载代码,不能调试代码。
顶一个。
在交流中前进,共同实现nios的应用。
不错!谢谢了!刚发现,试试
想看更多的东西?来我的博客,精彩多多! http://blog.eccn.com/u/bjxiong/index.htm
嗯,楼住说的有道理,不过怎么看出NIOS的频率是不是提高了呢?
