[求助]spartan2e xcs300e-6pq208 map 无法通过
我做的是以太网控制器,在综合之后的MAP时出现这样的提示错误,我查了好多
资料同时也尝试了很多时序约束的设置以及AREA GROUP的设置都不可以?请高手
指点迷津!我将感激不尽!
错误提示:Design Summary
   Number of bonded IOBs:           208 out of    142  146%
(OVERMAPPED)
Section 1 - Errors
ERRORack:18 - The design is too large for the given device and
package.
   Please check the Design Summary section to see which resource
requirement for
   your design exceeds the resources available in the device.
If the slice count exceeds device resources you might try to disable
   register ordering (-r).  Also if your design contains AREA_GROUPs,
you may be
   able to improve density by adding COMPRESSION to your AREA_GROUPs
if you
   haven'
版主您好:
那有什么解决问题的办法吗?希望您给点指导!我已经被这个问题困惑好久了,
综合的时候除了如下
WARNING:Xst:916 statem.v line 203: Delay is ignored for synthesis.的提示外没有其它问题,
除了换器件,有没有其它解决办法啊!感谢您的无私帮助
谢谢版主的建议 我试试!
