请教Protel99SE PCB DRC出错问题
Processing Rule : Clearance Constraint (Gap=0.2mm) (On the board ),(On the board )
   Violation between Text "0.1" (337.6792mm,297.9426mm)  BottomLayer and
                     Pad C26-1(339mm,296.911mm)  BottomLayer
Rule Violations :1
Processing Rule : Short-Circuit Constraint (Allowed=Not Allowed) (On the board ),(On the board )
Rule Violations :1
Processing Rule : Broken-Net Constraint ( (On the board ) )
   Violation         Net NetC26_1   is broken into 2 sub-nets. Routed To 0.00%
     Subnet : C26-1
     Subnet : U3-5
Rule Violations :1
看这出错提示没明白是哪里的问题,请高手指点一二,谢谢!
本想把那部分出错的截图放上来的看看的,可是上传时也出现下面的出错信息:
ADODB.Stream 错误 '800a0bbc'
写入文件失败。
/uploadTwo.inc,行175
人活着不仅仅是为了自己
[upload=image/pjpeg]uploadImages/99se-err.jpg[/upload]
没人碰到此类问题还是...?
人活着不仅仅是为了自己
惭愧,找到问题所在,低级错误!
人活着不仅仅是为了自己
1. 间距错误
2.网络短路
3.未连接网络
不知道楼主所犯的是???
看出错信息是这些!
实际是自己不小心把另一个贴片电容的容量值0.1由底层丝印层改到布线层了,而且又被隐藏的,所以一开始怎么也没找到,^_^!
人活着不仅仅是为了自己
