编译预处理语句 if-else语句 03
11: 奇分频
实现奇数(N)分频,分别用上升沿计数到(N-1)/2,再计数到N-1;用下降沿计数到(N-1)/2,再计数到N-1,得到两个波形,然后把它们相或即可得到N分频。代码如下:
module fp_odd(clk_out,clk_p,clk_n,clk_in,rst);
output clk_out;
output clk_p,clk_n;
input clk_in,rst;
reg [2:0] cnt_p,cnt_n;
reg clk_p,clk_n;
parameter N=5;
always @ (posedge clk_in or negedge rst)
begin
       if(!rst)     cnt_p<= 0;
       else  if(cnt_p==N-1)    cnt_p<=0;
                elsecnt_p <= cnt_p + 1;
end
begin
    if(!rst) clk_p <= 0;
    else if(cnt_p==(N-1)/2)
               clk_p<= !clk_p;
       else if(cnt_p==N-1)
               clk_p<= !clk_p;
end
always @ (negedge clk_in or negedge rst)
begin
       if(!rst)     cnt_n<= 0;
       else  if(cnt_n==N-1)    cnt_n<=0;
                elsecnt_n <= cnt_n + 1;
end
begin
    if(!rst) clk_n <= 0;
    else if(cnt_n==(N-1)/2)
               clk_n<= !clk_n;
       else if(cnt_n==N-1)
               clk_n<= !clk_n;
end
assign clk_out = clk_p | clk_n;
endmodule
