[求助]用modelsim作后仿真的问题!请大家指教!
载入.vo和.sdo文件后,编译仿真出现以下错误:
# Loading F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo # ** Error: (vsim-SDF-3250) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo(35): Failed to find INSTANCE '/video_top_tb/DDRRAM_FIFO|ddrram_ctl|ddr_dqs_l|altddio_bidir_component|ddio_bidir[0]|ioatom/asynch_inst'. # ** Error: (vsim-SDF-3250) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo(49): Failed to find INSTANCE '/video_top_tb/DDRRAM_FIFO|ddrram_ctl|ddr_dqs_h|altddio_bidir_component|ddio_bidir[0]|ioatom/asynch_inst'. # ** Error: (vsim-SDF-3250) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo(63): Failed to find INSTANCE '/video_top_tb/DDRRAM_FIFO|ddrram_ctl|ddr_dq_l|altddio_bidir_component|ddio_bidir[0]|ioatom/asynch_inst'. # ** Error: (vsim-SDF-3250) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo(77): Failed to find INSTANCE '/video_top_tb/DDRRAM_FIFO|ddrram_ctl|ddr_dq_l|altddio_bidir_component|ddio_bidir[1]|ioatom/asynch_inst'. # ** Error: (vsim-SDF-3250) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo(91): Failed to find INSTANCE '/video_top_tb/DDRRAM_FIFO|ddrram_ctl|ddr_dq_l|altddio_bidir_component|ddio_bidir[2]|ioatom/asynch_inst'. # ** Warning: (vsim-SDF-3432) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo: This file is probably applied to the wrong instance. # Ignoring subsequent missing instances from this file. # ** Warning: (vsim-SDF-3440) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo: Failed to find any of the 2904 instances from this file. # ** Warning: (vsim-SDF-3442) F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo: Try instance '/video_top_tb/video_top'. It contains all instance paths from this file. # ** Error: (vsim-SDF-3445) Failed to parse SDF file "F:/research/DDRSDRAMtest/EP1C6Q240/simulation/modelsim/video_top_v.sdo". # Time: 0 ps Iteration: 0 Region: /video_top_tb File: F:/research/DDRSDRAMtest/EP1C6Q240/video_top_tb.v # ** Error: (vsim-7) Failed to open SDF file "video_top_v.sdo" in read mode. # No such file or directory. (errno = ENOENT) # ** Error: (vsim-SDF-3445) Failed to parse SDF file "video_top_v.sdo". # Time: 0 ps Iteration: 0 Region: /video_top_tb File: F:/research/DDRSDRAMtest/EP1C6Q240/video_top_tb.v # Error loading design
是不是还有什么库没有编译,请大家指教! |
